Damn Hard Top/Door Alignment - JeepForum.com
post #1 of 5 Old 10-22-2013, 10:06 PM Thread Starter
Dingo1033
I finally took the maiden voyage after a month of the Jeep being down with the head job. Now I've put the hard top on and hard doors, but the drivers side door won't line up, it did last year when I took it off. I played with the stricker. I can't get 2 off those damn torx bolts out from the door hinge. I finally found a couple washers to fit the bottom pin and sorta shim it to line it up (it closes). I know I've gotta replace all of em with grade 8 bolts. Now to my question. The door hinges are concave so that the torx heads are flush with the hinge. Will I be able to replicate this with regular bolts?
"I may not change the world, but I'll damn sure leave a scar"
Dingo1033 is offline
post #2 of 5 Old 10-23-2013, 10:31 AM
superj
probably not but ask your local nut and bolt shop, not a hardware store or auto parts place. those types of holes are called countersunk holes so tell them you need bolts for countersunk holes
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 5 Old 10-23-2013, 10:36 AM
bentbolt
I had the problem with my old jeep and I couldn't find a bolt at hardware store so I got some at the junkyard
bentbolt is offline
post #4 of 5 Old 10-23-2013, 12:29 PM Thread Starter
Dingo1033
Ok thanx. I've got a Fastenal right down the road from me. I'll just take the Jeep there and ask em
post #5 of 5 Old 10-23-2013, 06:12 PM
superj
Sounds good
superj is offline
