d44s, choices, choices - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > d44s, choices, choices
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 02-11-2002, 04:52 PM   #1
JYRUS
was getting ready to put a scoutt d44 in the rear of my yj but today i just purchased a 92 jeep d44 out of a cherokee for $20 because it has a busted shaft and a tube might be bent and i say might be.would it be easier to repair the jeep d44 and use it or the scout. cant you straighten a bent tube? they both will take work to use. i will regear either way but i want have to redrill the flages on the jeep axle and it is the same width unlike the 58' scout axle. but the scout axle uses bigger brake drums!!! also since i am doing a spring over can i use the stock mounts from the cherokee and use shims to correct the angle like a cherokee lift uses or will i need to replace them to?
JYRUS is offline   Reply With Quote
Unread 02-12-2002, 02:28 AM   #2
love24wheel
the easiest thing to do would be to use the scout axle, and get 1" spacers for each side, that also convert the lug pattern to 5 on 4.5.. total cost for the spacers/adapters.. abotu 100 bucks from www.performancewheel.com
this will gi ve you a 60" wide D44 without a bent tube..
Scott
89 yj with tires and stuff like that.....
[url=http://www.amsoil.com/redirect.cgi?zo=1495622&page=store]Buy [color=red]AMS[/color][color=blue]OIL[/color] Products Here![/url]
[url=http://www.amsoil.com/redirect.cgi?zo=1495622&page=amsoillogin/preferredapp]Become an [color=red]AMS[/color][color=blue]OIL[/color] Preferred Customer![/url]
[url=http://www.amsoil.com/redirect.cgi?zo=1495622&page=info]Be your own boss- Sell [color=red]AMS[/color][color=blue]OIL[/color] Products![/url]
[url=http://www.heiseroil.com]Visit My [color=red]AMS[/color][color=blue]OIL[/color] Dealer Website![/url]
Black Jeep Member #22
love24wheel is offline   Reply With Quote
Unread 02-12-2002, 07:06 AM   #3
RodeoRob
probably less work to use the scout (assuming the tube is bent on the Jeep D44)
you can, this would involve re-tubing the axle... not a particularily easy job if you don't have the right tools or experience.
is the scout axle already 5 on 4.5?? i would have figured you'd have to redrill it as well as its probably 5 on 5.5.
2" less (1" on either side) is not that big of a deal. you could probably run that with no spacers. the common Ford 8.8 swap, that axle is around 58".
Since its in the rear, I seriously doubt the increase in drum size from the Jeep D44 will make any bit of difference in your stopping power.
spring perches? Assuming they line up (which i believe they will), yes, you could reuse them and just use degree shims to adjust the pinion angle.
Just another note... i'm not entirely sure about the rear axles, but I know the original Scout (not Scout II) front D44s are not that desirable as they have zero degree caster and they're one of the weakest D44s out there. Not sure if the rear possess the same weak characteristics the front does.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
robgorrell@yahoo.com - website
RodeoRob is offline   Reply With Quote
