D44 and D60 question... - JeepForum.com
post #1 of 13 Old 02-15-2012, 10:22 PM Thread Starter
Dallas333
Don't know a ton about axles and axle swaps, but I'm thinking I'm keeping my jeep for a long while so I'm starting to look at engine and axle swaps. Wondering if these axles would work for my jeep and after buying, what kind of expenses am I looking at to make me ready to be put in?
http://waco.craigslist.org/pts/2834469426.html
Also, is this a good price for both if they will work? Thanks in advance gents!
1999 Chili Pepper Red TJ, 4.0, 5 speed, 4 inch Pro Comp lift.
Disclaimer: We should all have hope and look towards the day where man realizes that the sounds exiting his mouth are mostly complaints and a change occurs. - Chevelle
Dallas333 is offline
post #2 of 13 Old 02-15-2012, 11:31 PM
scubamc
They are not going to be a direct bolt it if that is what you are asking. You will need to remove brackets and weld new spring perches and shock tabs on. What size tires are you planning on running? With a 60 in the rear 37" tire is almost to small for ground clearance for the diff so you need to be thinking real hard about running 40s. Is this your daily driver? If so that four banger is not going to like this setup.
It looks like they are probably junkyard pulls. So plan on complete rebuilds. Figure you will spend 2k minimum to get them under your Jeep. That's if you keep them full width and do not cut them down.
scubamc is offline
post #3 of 13 Old 02-15-2012, 11:39 PM Thread Starter
Dallas333
Whoa... Thanks for the info! May as well delete this thread lol. I'll just wait on an 8.8
post #4 of 13 Old 02-15-2012, 11:47 PM
plumber1
Look for the 8.8 or a dana 44
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
post #5 of 13 Old 02-16-2012, 07:07 PM
VACJ5
Yeah, I have those exact axles... full width HP44/HD60 rear. Those look like they can use a rebuild, then you have spring perches, shock tabs and steering. You can use your springs and even keep the factory mounts. The pricey part will be the steering, might as well go hi steer. You can get a conversion u joint to run the driveshafts you have now. It is doable... but it will be a decent chunk of money. Cheaper if you can weld but it is a killer setup!
79 CJ5 Silver Anniversary Edition... revived & sold *sniff
91 YJ 4.0 L, with some stuff bolted to it...
91 2 door Cherocar... in progress
Custom CNC cut Jeep parts & more
VACJ5 is offline
post #6 of 13 Old 02-16-2012, 07:16 PM
2doorxj
2doorxj's Avatar
37s is pushing it for a dana 44, 40s are much too big. Also that rear 60 would need to have the spindles bored to accept 35 spline shafts otherwise its not strong enough for 40s either. Personally i would just go to one tons if youre going to do that much work.
No need to cut them down, just run some hummer h2 wheels on it, or another wheel with a lot of backspacing.
Make sure you have access to a welder/fab tools and are able to have your jeep on jackstands for quite some time before you commit to doing a swap like that.
2012 Cherokee of the Year
2doorxj is offline
post #7 of 13 Old 02-20-2012, 03:08 PM Thread Starter
Dallas333
Ford 8.8
Ok, found this one on CL...
___________________________
FOR SALE $125 OBO $85 cash
removed from 2002 ford f150 LWB 5spd v6 - complete rear end with brakes rotors hubs calipers leaf spring suspension etc....
has a bad axle seal , good for parts replacement projects scrap metal hot rod hotrod truck pickup car 351 289 302 5.0
____________________________
I would have to have it regeared, but he's asking $85 for everything... I could probably get him down to $60. Would this be a good candidate for a swap?
post #8 of 13 Old 02-20-2012, 03:29 PM
scubamc
It will be wider than the Explorer 8.8 and the bolt pattern will not match the 5x4.5 bolt pattern.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #9 of 13 Old 02-20-2012, 03:50 PM
wrngleryj
To the OP I know this is a little off topic, but would anyone know the lowest gear ratios you can swap into the ford 8.8 or the Dana 44?
wrngleryj is offline
post #10 of 13 Old 02-20-2012, 03:59 PM
scubamc
5.13 on the 8.8 and 5.38 on the 44. That's off the top of my head without doing any research. I could be wrong.
scubamc is offline
post #11 of 13 Old 02-20-2012, 05:03 PM
fratis
fratis's Avatar
nothing wrong with a 60 and 35" tires. the ground clearance issue isnt that big of a deal especially spring-under. theres more clearance issues to deal with.
a 60 and 44 combo that match would be a fine thing to swap in. no need do the 8.8 like everyone else only to be stuck in terms of a front axle swap. id do a 60 over an 8.8 any day particularly if i could get a matching hp d44 for the front and rid myself of the turdy.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #12 of 13 Old 02-20-2012, 07:08 PM
hesserdude07
X2... i ran a 14 bolt and hp 44 in my old chevy on 36s. And i swapped to CTM u-joints and ran 44" TSLs on the dana 44 front axle and never broke it while i owned it in 1.5yr.
You can run 35s on your front dana 30, just swap the rear...
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #13 of 13 Old 02-20-2012, 08:53 PM
wrngleryj
Sounds good. Thanks!
