D35 vs AMC20 - JeepForum.com
post #1 of 6 Old 04-01-2010, 09:56 AM Thread Starter
BioTex
1979 CJ7
D35 vs AMC20
Just curious, which is considered stronger? The AMC20 in my CJ has held up well with 33's, and am wondering about my newly aquired 88 YJ. It also has 33's.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #2 of 6 Old 04-01-2010, 09:59 AM
MLJeeper
MLJeeper's Avatar
AMC 20 with the one piece shafts can easily handle 33s. Its still not a "great" dif. But its decent, i put it in the same class as Chrysler 8.25
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #3 of 6 Old 04-01-2010, 10:18 AM Thread Starter
BioTex
1979 CJ7
Ok, so what about the D35? Stronger or weaker? They came factory with one piece axles correct? Talking in 88
Currently:
BioTex is offline
post #4 of 6 Old 04-01-2010, 10:29 AM
planedog
The AMC 20 is generally consider a lot stronger than the 35. It has larger axle shafts.
planedog is offline
post #5 of 6 Old 04-01-2010, 10:38 AM
MLJeeper
MLJeeper's Avatar
And a large ring and pinion. I also should qualify that as the amc being approximately equal to a 29 spline 8.25. I know several who run 35s on the amc 20 and 29 spline 8.25 with rare breakage.
The d35 is by far the weaker unit.
MLJeeper is offline
post #6 of 6 Old 04-01-2010, 11:46 AM Thread Starter
BioTex
1979 CJ7
I was afraid of that! I wanted to be sure before I go crawling it. I was told it was locked, but I haven't had a chance to pull the cover yet. Reading the factory specs in the FAQ's, mention was made to some canadian models being D44's. I found a sticker on the door bottom that said it was made in Canada. Maybe I got lucky, but it would be a first. If it's a D35, I will have to chunk it. I have a D60 (4.10) I was saving for a crawler project.
Currently:
BioTex is offline
dana 44 and amc20 bulrokyj YJ Wrangler Technical Forum 6 02-12-2010 04:28 PM
Swap CJ wide-track AMC20 for AMC35 possible? operous YJ Wrangler Technical Forum 4 11-07-2009 04:19 PM
D44/amc20(1 piece) -vs- D30/D35 BigDeaner YJ Wrangler Technical Forum 5 02-22-2009 03:02 PM
'77 waggy axles for swap... D44 or AMC20 in rear? Burlbook48 YJ Wrangler Technical Forum 2 11-14-2008 10:28 PM
AMC20 rears axle from waggy 86comanche YJ Wrangler Technical Forum 2 08-07-2008 11:31 AM
