D30 rt axle seal(solid axle shaft)_ - JeepForum.com
post #1 of 25 Old 05-10-2013, 04:29 PM Thread Starter
rykemc
Have a question. I installed some chromoly axle shaft and have a leaking passenger side seal. I am sure I probably screwed it up sliding the shaft in. I do have a question though, is there suppose to be two seals on that side. The one at the carrier and then another one near the CAD?
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #2 of 25 Old 05-10-2013, 04:43 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
One at the carrier and that's it.
Napa oil seal #11800
Luck Favours The Prepared
Anticanman is offline
post #3 of 25 Old 05-10-2013, 04:45 PM
dillonjm
2013 WK
This^^
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #4 of 25 Old 05-10-2013, 04:53 PM Thread Starter
rykemc
CRAP!!!!!!!!!!! I was hoping there was suppose to be one at the CAD also and I just forgot to install that one
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #5 of 25 Old 05-10-2013, 05:55 PM
dillonjm
2013 WK
You may have had some residual oil left down in the tube from before you swapped that is just now showing itself too. May not be time to freak out yet!
Then again, you may have just damaged the seal when you installed the shaft too. That happens occasionally.
dillonjm is offline
post #6 of 25 Old 05-10-2013, 06:02 PM Thread Starter
rykemc
This. Housing was stripped and cleaned before axles were put in. I damaged the seal
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #7 of 25 Old 05-11-2013, 12:51 PM Thread Starter
rykemc
The napa seal 11800 inside diameter is to small for my axle shaft, also does that seal go here?
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #8 of 25 Old 05-11-2013, 12:58 PM Thread Starter
rykemc
FYI, I am running the Alloy USA chromoly front axle shaft kit with the 30 spline axles.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #9 of 25 Old 05-11-2013, 02:46 PM
kojak70
I have part number on invoice at home. If no one gets it to u I will tonight
kojak70 is offline
post #10 of 25 Old 05-11-2013, 02:54 PM Thread Starter
rykemc
[QUOTE=kojak70;15420174]I have part number on invoice at home. If no one gets it to u I will tonight[/QU
Thank you so much
Let me know when you get it. I sent an email to USA tech and the response was "We will let you know in 2 business days" F' that.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #11 of 25 Old 05-11-2013, 03:08 PM Thread Starter
rykemc
Would need to call quadratec but I am wondering if those are for the tube seals at the end of the axle tubes?
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #12 of 25 Old 05-11-2013, 03:28 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The 30 spline shafts are a little bigger and have their own seal.
post #13 of 25 Old 05-11-2013, 03:55 PM Thread Starter
rykemc
No S***
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #14 of 25 Old 05-11-2013, 05:13 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Had you mentioned it in the first post or profile then it would have been solved earlier.
post #15 of 25 Old 05-11-2013, 09:57 PM
kojak70
I'm much more organized in my head than in reality. hehe. Just got home and the invoice is not in the "stack" I know I put it in. Someone must have snuck in and moved it. obviously I will look in my other stacks in morning.
kojak70 is offline
