-   -   D30 rt axle seal(solid axle shaft)_ (http://www.jeepforum.com/forum/f12/d30-rt-axle-seal-solid-axle-shaft-_-1521576/)
rykemc 05-10-2013 03:29 PM
Have a question. I installed some chromoly axle shaft and have a leaking passenger side seal. I am sure I probably screwed it up sliding the shaft in. I do have a question though, is there suppose to be two seals on that side. The one at the carrier and then another one near the CAD?
Anticanman 05-10-2013 03:43 PM
One at the carrier and that's it.
Napa oil seal #11800
dillonjm 05-10-2013 03:45 PM
This^^
rykemc 05-10-2013 03:53 PM
CRAP!!!!!!!!!!! I was hoping there was suppose to be one at the CAD also and I just forgot to install that one :(
dillonjm 05-10-2013 04:55 PM
You may have had some residual oil left down in the tube from before you swapped that is just now showing itself too. May not be time to freak out yet!
Then again, you may have just damaged the seal when you installed the shaft too. That happens occasionally.
rykemc 05-10-2013 05:02 PM
This. Housing was stripped and cleaned before axles were put in. I damaged the seal :(
rykemc 05-11-2013 11:51 AM
2 Attachment(s)
The napa seal 11800 inside diameter is to small for my axle shaft, also does that seal go here?
Attachment 625530
Attachment 625531
rykemc 05-11-2013 11:58 AM
FYI, I am running the Alloy USA chromoly front axle shaft kit with the 30 spline axles.
kojak70 05-11-2013 01:46 PM
I have part number on invoice at home. If no one gets it to u I will tonight
rykemc 05-11-2013 01:54 PM
[QUOTE=kojak70;15420174]I have part number on invoice at home. If no one gets it to u I will tonight[/QU
Thank you so much :cheers2:
Let me know when you get it. I sent an email to USA tech and the response was "We will let you know in 2 business days" F' that.
rykemc 05-11-2013 02:08 PM
Would need to call quadratec but I am wondering if those are for the tube seals at the end of the axle tubes? :confused:
Anticanman 05-11-2013 02:28 PM
The 30 spline shafts are a little bigger and have their own seal.
rykemc 05-11-2013 02:55 PM
No S*** ;)
Anticanman 05-11-2013 04:13 PM
Had you mentioned it in the first post or profile then it would have been solved earlier.
kojak70 05-11-2013 08:57 PM
I'm much more organized in my head than in reality. hehe. Just got home and the invoice is not in the "stack" I know I put it in. Someone must have snuck in and moved it. obviously ;) I will look in my other stacks in morning.
The time now is 02:22 AM.
