D30 gearing? - JeepForum.com
post #1 of 24 Old 09-03-2011, 09:38 PM Thread Starter
DoozerPeej
D30 gearing?
Okay so I am sure there are a ton of threads but instead of bringing up an old post, I figured I would start a new one so I can have recent build experience and trail experience. I am wanting to build up my Dana 30 HP and I am thinking of gearing while I am at it. My question is, I have 3.07 gearing now but I am wanting to go to 4.88. Am I correct in that I will need to get a new carrier? because the 3.73 and up (numerically) have a different carrier than the ratios below it? Also will a rebuild kit (carrier bearings, pinion bearings, pinion seal) for the 3.07 gears work with a 4.88 gearing? or will I have to get bearings for the new ratio. I am also planning on building a ford 8.8 for the rear. I know they come in 4.10 gears, so if I get one with that gearing I wouldn't have to replace the carrier for the new 4.88 right? any input, advice, pro's and con's would be great. Its 90% a trail rig but nothing crazy hard. I have 33"s and the 4.2 with the ax15/np231 combo.
DoozerPeej is offline
post #2 of 24 Old 09-03-2011, 10:28 PM
timatoe
timatoe's Avatar
Yes new carrier for 3.73 and up, bearings, seal etc. are the same. The 8.8 doesn't have a carrier break.
timatoe is offline
post #3 of 24 Old 09-03-2011, 10:46 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
If you are going with the 8.8 Ford Explorer axle (with disc brakes I hope) why don't you find a HP Dana 30 out of a Cherokee with a 4 cylinder engine (at your local junkyard) so you won't have to re-gear anything for a while. It will give you 4.10/4.11 gears, and stronger axles and minimal cost.
Just a thought.
Group W Bench
CRAWLING 98 is offline
post #4 of 24 Old 09-03-2011, 10:56 PM
Boodyrider
HP30... just don't forget the GEARS themselvs are different (reverse rotation) compared to a low pinion. Carriers (and lockers), install kits, seals, etc. all can be used in either low or high pinion. Carrier DOES need to be changed to go 3.73 or higher if original were 3.07. And best suggestion so far is bolt in a 4 cyl HP30 that HAS 4.10 already, and install the 8.8 that you bought WITH 4.10s in it.
I have an uto TJ Sport, 35s and 4.88s. 4.10s will do quite nicely with the 33s and a stick. you don't really need 4.88s, and should consider whether the slight difference is worth the cost of regearing both axles over what you can simply buy them with. Add at least 1000 bucks to regear. Why not save that money, or better yet spend it on lockers or RCV shafts?
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #5 of 24 Old 09-03-2011, 11:04 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
I got an 8.8 with 4.10 and then found a d30 out of a 95 yj with 4.11's which is a HP and is a direct bolt in. my jeep was 3.55 stock and 4.10 with 33 puts me almost back to stock rpm band. so i think 4.88 is way overkill unless you are going to go with bigger tires in the future. you going from 3.07 to 4.10 with 33's is going to be very noticeable.
To view the NEW
click here!!!
tobias94yj is offline
post #6 of 24 Old 09-04-2011, 02:31 AM
fratis
fratis's Avatar
Just a thought.
just an opinion here but if you go this route then you will have an entire axle assembly rotting on the side of your house. its awful and if you stick it there "for now" it will be there for years. 4.10:1 with 33s suck. it might be fine for the highway but offroad it will be a pain. i know a lot of guys on here use that combo but i think its mostly out of convenience, like suggested here, then what is really desired. how will the axle shafts be stronger? if you are actually referring to the "larger" ujoints i have always disagreed with this assumption. ive seen way too many of both break to definitively say one will survive better then another. all of the 30 shafts i broke were at the splines and never did wreck a ujoint (smaller ones.)
why do so many people "fear the regear?" its not rocket science and can be done by your average garage tinkerer or easily taken to someone else.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #7 of 24 Old 09-04-2011, 09:26 AM
jeepinmichguy_
Just a thought.
YJ's come with HP30's.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #8 of 24 Old 09-04-2011, 10:38 AM
timatoe
timatoe's Avatar
Yeh, I was a little confused by that entire post.
timatoe is offline
post #9 of 24 Old 09-04-2011, 10:42 AM
jeepinmichguy_
Most TJ guys don't know any better.
ΜΟΛΩΝ ΛΑΒΕ
post #10 of 24 Old 09-04-2011, 10:48 AM Thread Starter
DoozerPeej
Well I am a mechanic so its only the cost of parts, labor is free. The only reason I was thinking of going to 4.88 is because its the lowest gearing the HP30 can go, and like I said its a trail rig so the speeds on the street don't matter. Do all cherokees with the HP30 and 4 cylinder have 4.11 gearing? I haven't looked into how much a 3.73 carrier costs, but would it be worth the time to save the money and get one a 4.11 carrier from a junkyard?
post #11 of 24 Old 09-04-2011, 11:06 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
How about we backtrack just slightly?
Are you willing to pull a HPD30 from an XJ, then cut off the passenger side upper control arm mount (the driver side upper control arm mount is cast into the top of the housing, so generally you'd leave it there).
Then remove all the lower control arm mounts.
Remove the coil buckets.
Weld on new shock mounts (the XJ shock mounts are in a bad location to use with a leaf sprung YJ).
Weld on new spring perches and set the pinion angle correctly.
Migrate your YJ steering over to the XJ axle.
Do away with the YJ's stock tracbar and swaybar since the XJ uses a different set-up.
More than likely you can reuse your old spring plates (but weld closed some of the holes for the ubolts & redrill new holes where necessary) but get new ubolts & tall nuts since the XJ housing doesn't have the vacuum disco system if you get the right one. With an XJ housing, not all of your ubolts are the same size as the YJ's.
These are the minumum items you'd need to deal with if you swapped the "correct" non-disco XJ HPD30 housing that already has the gears you want.
If you are not willing to do all of what I mentioned above - then maybe get a YJ HPD30 from a 4cyl 5 speed & it'll have 4.10's from the factory & you won't have to deal with what I listed above.
Joe Dillard is offline
post #12 of 24 Old 09-04-2011, 11:29 AM
jeepinmichguy_
ΜΟΛΩΝ ΛΑΒΕ
post #13 of 24 Old 09-04-2011, 01:40 PM Thread Starter
DoozerPeej
I was meaning take the carrier out of the housing, I already have tj shafts in so I don't have the disconnect axles. If you read my post I was only talking about taking the carrier out of junkyard XJ
post #14 of 24 Old 09-04-2011, 01:52 PM
fratis
fratis's Avatar
carriers are like $60.00 new. totally not worth pulling from a yard.
fratis is offline
post #15 of 24 Old 09-04-2011, 06:41 PM
Mark05059
not when you can get a yj 4.11 axle that will bolt in directly and have the same thing... run the 8.8 with 4.10's while you gather parts for the 4.88 regear if you feel that you need it..
if you can live with it then your mission is complete without much work at all and you most likely have extra shafts/brake parts/etc left off of the old stock axle.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
gearing Doug Gross TJ Wrangler Technical Forum 10 03-23-2007 09:20 AM
4 Cyl gearing yjdrvr YJ Wrangler Technical Forum 3 03-18-2007 07:54 PM
gearing up for my 33s Mondo TJ Wrangler Technical Forum 22 03-08-2007 08:28 PM
Swapping a 30/35 with 3.07 gearing for a 30/35 with 4.10 gearing...? Erik T. TJ Wrangler Technical Forum 13 10-02-2006 09:58 PM
Gearing in differential and gearing in t-case, little help ... farinspace TJ Wrangler Technical Forum 6 03-06-2005 02:31 PM
