D30 to D44 and driveshaft - JeepForum.com
post #1 of 8 Old 09-25-2013, 06:21 PM Thread Starter
Reno72
A friend has a D44 with upgrade axle shafts, and selectable locker he wants to sell (G2) he's going bigger. I plan on an 8.8 in the near future and thought this would be a good upgrade for my front. Will I need a longer DS? I just had my front DS cut and balanced for my new lift.
Reno72 is offline
post #2 of 8 Old 09-25-2013, 08:46 PM
rambo3489
No your front DS should be fine. The pinions are about the same length. May I ask why your looking to go to the 44? In all honestly it's not all that much stronger than the 30. Unless your running deeper gears. Or going full widths. Otherwise it's basically a wash assuming they are both using 760 u-joints
Is it a high pinion D44? If not it's not worth it.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #3 of 8 Old 09-25-2013, 10:22 PM Thread Starter
Reno72
Thanks Rambo,I have a stock D30 right now. For the D30 I would need to change the gears to 4.56 (which I can't do) get stronger axles (which I haven't priced) and add the selectable locker. I'm trying to figure if the price I can get this D44 for would be cheaper than I would spend doing all the work on the D30. I'm figuring having someone do the gears could be $1000 parts and labor, me doing the locker would be $700-800, and the axles I'm not sure of, so I at least have about $1800 in the D30 which is what this guy wants for the G2 D44. Sometimes this jeep has my head spinning
Reno72 is offline
post #4 of 8 Old 09-25-2013, 10:25 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I tried calling you earlier & left a message. Give me a ring when you get a chance.
Joe Dillard is offline
post #5 of 8 Old 09-25-2013, 10:43 PM
TSEJEEPERS
What locker?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #6 of 8 Old 09-26-2013, 01:09 PM
rambo3489
Yea if the price is in the same ballpark I say then go with the 44. Is it already set up for a YJ?
<a href="
THE YJ MY WAY</a>
post #7 of 8 Old 09-26-2013, 05:36 PM Thread Starter
Reno72
Yes it's off a yj and has the ox locker, I'd just need to run the cable.
Reno72 is offline
post #8 of 8 Old 09-26-2013, 07:22 PM
rambo3489
I see no reason not to. Except you'll be without 4wd temporarily. But that's not an excuse to pass up a good deal.
Sent from my phone because I'm doing something "more important"
<a href="
THE YJ MY WAY</a>
