D30 ball joint replacement questions. - JeepForum.com
post #1 of 12 Old 09-24-2011, 06:01 PM Thread Starter
chrisoncoffee
I was quoted $680 dollars (with an employee discount) from the local Sullivan Tire to replace all 4. Needless to say I won't be shelling out that much money. I plan on doing it myself using this write up:
http://www.higherground4x4.com/forum...ep-XJ-YJ-or-ZJ
Here are my questions:
1. Sullivan tire sighted the fact that my vehicle is leaf sprung and not coils as a reason why the job was so labor intensive and expensive. After looking at my FSM I cannot figure out why this makes a difference at all. Can anyone think of why this might be? All the writeups I've found have been for coil sprung vehicles and it seems to me like the procedure would be the same but I don't want to be missing something before I rip everything apart.
2. Is there a way to make the autozone loaner tool workable or should I go out and buy one? If so what do people recommend?
Thanks for helping a n00b. Take care,
CB
chrisoncoffee is offline
post #2 of 12 Old 09-24-2011, 06:14 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
1) BS
2) Check out your local auto parts stores, rent the ball joint tool that has the most adapters. You can make the basic straight adapters do the job, it is just slightly more difficult. A full adapter kit has angled adapters to deal with Jeep steering knuckles.
For the next time, I have considered buying the Jeep/Chrysler adapter kit and then just renting the press.
The Harbor Freight ball joint press is too light weight for stubborn ball joints. The rental kits are usually professional quality tools.
CJ7-Tim is offline
post #3 of 12 Old 09-24-2011, 06:20 PM
ChicagoYJ
Yes, I Understand!
ChicagoYJ's Avatar
Get the loaner from Advance it's a complete kit. It comes with the adapters for 4X4's. The good thing is you can keep it (rent it) for 30 days and they give you every penny back.
ChicagoYJ is offline
post #4 of 12 Old 09-24-2011, 06:23 PM Thread Starter
chrisoncoffee
Awesome. Thanks for the responses. The extra labor for leaf springs blew my mind. I wonder what kind of games alldata is playing there. Wish me luck.
post #5 of 12 Old 09-24-2011, 06:39 PM
ChicagoYJ
Yes, I Understand!
ChicagoYJ's Avatar
If my memory serves me correctly I believe this is the part# at Advance:
http://shop.advanceautoparts.com/web...7CGRP2107_____
Just like this one but I used the OTC.
http://shop.advanceautoparts.com/web...7CGRP2003_____
Cost me 180.00 to rent about a year ago. Just make sure you let them know you want the kit that comes with the 4x4 adapters.
I don't remember having to do anything to or with my leafs when I did mine.
post #6 of 12 Old 09-24-2011, 07:00 PM
kloppk
You can do all 4 joints for about $200 with good joints.
I just did one side on my leaf sprung D30 this afternoon.
Used the loan-a tool press from AZ. You do have to shim the press when using it due to the angled "C".
I just used a screwdriver shaft to shim it.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #7 of 12 Old 09-24-2011, 07:19 PM
moonshinefuel
I did discuss ball joint replacement in a thread, looked into this subject some. Feel free to take a look here http://www.jeepforum.com/forum/f12/y...-30-a-1140042/
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #8 of 12 Old 09-24-2011, 08:04 PM
Slapahoe
Registered Jerk
Slapahoe's Avatar
I've done ball joints on three different Wranglers and two Blazers. A ball joint press from Harbor Freight is what I bought and it gets the job done flawlessly.
All you need is the harbor freight press, the ball joints with the proper cotter pins, a big enough socket for the nuts, beers, an afternoon, and some marine grease for the ball joints.
Super easy job.
93 YJ 4.0HO
'03 KJ Renegade
Slapahoe is offline
post #9 of 12 Old 09-25-2011, 02:58 AM
nembudonna
Sometimes they can be a real hassle to get out. Take your time and hang in there. Good Luck.
nembudonna is offline
post #10 of 12 Old 09-25-2011, 07:06 AM
sitedzn
Yep, I call BS too.
I bought this: http://www.harborfreight.com/automot...-kit-4065.html
Then, spent about 2 hrs (first time replacing ball joints so I was worried about breaking something) and I was done.
BTW, I have TONS of HFT stuff and never had an issue with any of it. I had a 24" breaker bar, with a 5' steel pipe on it, to get the ball joints off. Impact wrench didn't have enough a$$ in it.
88 YJ, 4.2L, AX-15, NP231 w/ SYE, 3.5" RC lift, 1" booms
Cut down XJ shaft in rear
Ford 8.8 LS & Spartan Locked
D30
Big Daddy Off Road rock sliders
35x12.5 BFG A/T KOs, XRC-8000
I love installing new stuff.
sitedzn is offline
post #11 of 12 Old 09-25-2011, 08:12 AM Thread Starter
chrisoncoffee
Thanks for all the responses. I'm gonna tackle this job today. One more question:
My FSM says I need to remove the shift motor for the 4wd but none of the write ups i've found mention this step. One of them suggested putting the truck in 4wd before jacking it up so as to keep the inner/outer axle shafts together. If I do that will I still need to remove the shift motor before reinstalling the axle shaft?
Thanks again for the responses.
post #12 of 12 Old 09-25-2011, 08:45 AM
Slapahoe
Registered Jerk
Slapahoe's Avatar
Originally Posted by sitedzn View Post
Yep, I call BS too.
And best yet, if you break something of theirs, you can always bring it back and claim that it was faulty. They'll tell you to go grab another one.
Not necessary. You should be able to pull the outer shaft out with out issue. You may have fluid leakage but I'd imagine your differential could possibly use a fluid change anyways.
93 YJ 4.0HO
'03 KJ Renegade
Slapahoe is offline
Ball joint wear/replacement questions jbeebe YJ Wrangler Technical Forum 31 04-08-2010 09:22 AM
Ball Joint Replacement RecklessJ TJ Wrangler Technical Forum 31 07-22-2009 10:15 AM
ball joint replacement jws1961 YJ Wrangler Technical Forum 9 05-07-2008 02:48 PM
Ball Joint Replacement DesertTJ TJ Wrangler Technical Forum 9 05-12-2007 09:12 AM
Ball joint replacement TheDuke05 TJ Wrangler Technical Forum 2 10-05-2006 11:50 PM
