d30 -> 2001 explorer sport TRAC 8.8 - JeepForum.com
post #1 of 11 Old 10-25-2011, 12:28 PM Thread Starter
jhumphrey
hey all,
so my dad found an 8.8 from a 2001 ford explorer sport trac at a local boneyard. he knew that i had been looking for one, so he bought it for me and called me all excited. i wasn't sure if a sport TRAC 8.8 is the same as the explorer 8.8.
I'm at work and did a quick search, but didn't reach a quick conclusion. some of the sites say that the sport trac's rear was 28 spline, others say 31. he told me that it had disc brakes and by all accounts that means it should be a 31 spline, correct? (https://www.fleet.ford.com/truckbbas...01/expstcd.pdf - about half way down it shows axle specs and lists it as 31 spline).
Other than splines, is there a difference between the explorer and the sport trac rear (length, diameter, etc). I just want to make sure this is the right thing, since my dad is several miles from me, id hate for us to get together only to find out this isn't right. it'd be easier for him to get his money back if its not right. oh, gear ratio is 3.73 by all accounts, which i plan to regear to 4.56 anyway.
thanks all!
jhumphrey is offline
post #2 of 11 Old 10-25-2011, 12:47 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Axle tube diameter is different (~1/4" smaller) according to the link you posted.
Joe Dillard is offline
post #3 of 11 Old 10-25-2011, 01:00 PM
aztec
i have a question that pertains to 8.8's.
so i finally have enough money to do the swap and was calling local junkyards and they asked me, 'is it 4x4 or not?' my quesion is: does it even matter?? is there such a thing as a 4WD 8.8 and a 2WD 8.8 other than that guy trying to charge me more money for the same thing?
aztec is offline
post #4 of 11 Old 10-25-2011, 01:10 PM
Joe Dillard
As long as it came from an Explorer (not Sport Trac) the axle itself is basically all the same with the exception of brakes ('91 - '94 = drums, '95 - '01 = discs) and the attached optional sway stuff between models.
So the important stuff (tubes, width, wheel bolt pattern, axle spline count (they are ALL 31 splines if it came from an Explorer) carrier spline count) inside is all the same.
2wd & 4wd doesn't come into play as far as internal strength.
post #5 of 11 Old 10-25-2011, 01:35 PM
aztec
thank you.
aztec is offline
post #6 of 11 Old 10-25-2011, 01:49 PM Thread Starter
jhumphrey
There isn't a difference. Just make sure it's from an explorer and NOT an explorer SPORT TRAC. Apparently (from the best i can gather), they are different in some ways. It is also worth noting that it doesn't matter if the explorer is a 6 cyl or 8 cyl. Heck, even gear ratios don't matter, if you're planning a regear, like me (4.56). Don't pay a premium because it's "4x4".
On that note, I called the boneyard. They confirmed that he bought the 8.8 from a 2001 explorer SPORT, not a sport trac, so I'm golden . I can rest easy now!
"A woman's body is a work of art. A man's body is a utilitarian. It's for gettin' around. It's like a Jeep." - Elaine Benes
post #7 of 11 Old 10-25-2011, 01:57 PM
Joe Dillard
Nice! Looks like it should workout just fine.
post #8 of 11 Old 10-25-2011, 02:04 PM
aztec
right on! thanks for the advise and good luck on your build.
aztec is offline
post #9 of 11 Old 10-25-2011, 02:27 PM
jeepster93
jeepster93's Avatar
The Ford 8.8 came on Crown Vics, Mustangs, E-150 Vans, F-150 pick ups and many things in-between. Ford got good use out of the 8.8 for sure.
jeepster93 is offline
post #10 of 11 Old 10-25-2011, 02:38 PM
jbolty
jbolty's Avatar
The good news is that almost all the Explorer Sport seem to have 4:10 gears.
If it's from a sport trak it is almost certainly NOT a 31 spline axle. The sport trak is built off a ranger pickup base and only a very, very small number have the "good" 8.8
jbolty is offline
post #11 of 11 Old 10-25-2011, 04:00 PM Thread Starter
jhumphrey
Yeah, I was panicking there for a little bit because I could've sworn he said it was a sport trac. I called the yard and they said it was from an explorer sport, which made me feel MUCH better.
I know that a sport trac made after aug 02 - 05 has the 31 spline 8.8, from what I read. Another article I read said anything before that was 27 spline (ford ranger series). That would've been bad. I'm sure my dad could've taken it back, but that's a lot of hassle...
I still piecing together everything I need for the swap. I'm just excited to have the actual axle . As far as I know, it has 3.73 gears in it, but I plan to put 4.56s in anyway. Overall, my 8.8 project is going to be higher than originally planned, but I did get a great deal on the axle, so that levels it out some...
Sport Trac 8.8 flys_yj YJ Wrangler Technical Forum 1 01-21-2009 10:47 PM
2000 explorer sport 8.8 stib4 YJ Wrangler Technical Forum 8 10-25-2007 12:34 PM
How to tell if my 2001 tj has a trac-lock? alex71 TJ Wrangler Technical Forum 11 02-26-2007 02:15 PM
Explorer Sport Trac 8.8 Bill E. TJ Wrangler Technical Forum 4 02-01-2006 05:00 PM
Ford 8.8 in explorer SPORT also?? Houston Terrell TJ Wrangler Technical Forum 1 11-17-2004 08:28 PM
