D.U.I. HEI Install Problems - JeepForum.com
post #1 of 14 Old 04-05-2013, 09:51 PM Thread Starter
OilfieldCowboy
87 258, Nuttered, TBI'd.
Installed the DUI, hooked positive direct to battery post, 12.4v at the distributor. Cranked the engine, fired right up, ran smooth for about 5 seconds, started smelling frying electronics. Killed the engine, now there is no spark.
Is there any idea on what burned up? We are all guessing that the coil in the HEI is what got fried. I'm hoping I can just hit NAPA in the morning and get a new one, but I won't hold my breath on that one.
2006 Rubicon Unlimited
OilfieldCowboy is offline
post #2 of 14 Old 04-05-2013, 10:53 PM
timatoe
timatoe's Avatar
Napa will have a new coil. Don't know what or why anything would've fried though.
timatoe is offline
post #3 of 14 Old 04-06-2013, 07:58 PM Thread Starter
OilfieldCowboy
Turns out its a fuel issue. What wire from the OEM ignition module do I need to supply power to so my fuel pump will run?
post #4 of 14 Old 04-06-2013, 09:54 PM
timatoe
timatoe's Avatar
I don't remember what wire it is and didn't realize you had a Howell setup. Check out their website, they have the install instructions right there, that should help with the troubleshooting.
timatoe is offline
post #5 of 14 Old 04-06-2013, 10:54 PM Thread Starter
OilfieldCowboy
Another question, what all can I remove from the OEM Duraspark ignition wiring when swapping to an HEI? Module is a no brainer on the removal. I obviously did not research this project enough prior to ordering. Don't normally do that.
post #6 of 14 Old 04-06-2013, 11:38 PM Thread Starter
OilfieldCowboy
Helps if I look through some of JeepHammers unbelievably awesome posts:
Originally Posted by JeepHammer View Post
You can control the "Low Current" switching to the relay, which is what you see above.
The Ignition switch controls the HEI relay low voltage trigger power,
post #7 of 14 Old 04-07-2013, 10:50 AM
timatoe
timatoe's Avatar
I run a relay to mine like the above pic. As for the ignition wiring,,,,, the only thing I left was the 12v signal that I ran to the relay. Otherwise everything (other than tach) that was part of the original system was cut out and removed.
timatoe is offline
post #8 of 14 Old 04-07-2013, 11:02 AM Thread Starter
OilfieldCowboy
Found this in the CJ forum:
Originally Posted by CSP View Post
Since you've removed the original ignition those "purple wire" instructions aren't applicable any longer. All that you have to do is connect the white wire that, IIRC, goes to the negative post of the coil to the "TACH" terminal on your distributor. Ignore the stuff about the purple wire and the splices.
Connected the white wire with the TACH post on the distributor and it fired up on the second crank. Don't have a functional tach at the moment, but at least its running and I can try and get my timing half way sorted out until I can get the tach working.
post #9 of 14 Old 04-07-2013, 11:24 AM
roadyrob
1987 YJ Wrangler
just checked my 87. the tach is the green wire with white stripe.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #10 of 14 Old 04-07-2013, 11:26 AM Thread Starter
OilfieldCowboy
I'll splice that one in later today and see if it will get the tach up and functional before attempting anything with the timing.
post #11 of 14 Old 04-07-2013, 04:47 PM Thread Starter
OilfieldCowboy
Green w/ white trace is wired into the tach output, I now have a solid RPM reading on the gauge.
Relay is wired up as per the schematic above, new issue; the sunovabich diesels when the key is turned off! So bad I've had to put it in first and dump the clutch to finally kill it. Wondering if this isn't an issue with the Howell ECM now...
post #12 of 14 Old 04-07-2013, 05:43 PM
timatoe
timatoe's Avatar
What's your timing at now?
timatoe is offline
post #13 of 14 Old 04-07-2013, 05:56 PM Thread Starter
OilfieldCowboy
Haven't even got that far as I pulled the jeep out of the garage to let it get to operating temp, and thats when I noticed the dieseling. Could that be timing related? Planning on setting it around 7*BTDC.
post #14 of 14 Old 04-07-2013, 07:23 PM
jay-h
Is it starting ok hot?
I ask because I had a problem with my Howell though with a Duraspark. The timing retard wire was not hooked up and it was troublesome starting warm.. flooding and other issues. Worked much better when I fixed that. My understanding is that the HEI does not have a timing retard at all so it would seem to have a similar problem?
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
