D ring falling off - Page 3 - JeepForum.com
post #31 of 53 Old 08-01-2013, 12:17 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by SeanB95YJ View Post
..... clevis pin type, which instead of a threaded bolt is basically a pin similar to a hitch pin. you can either use the type with a cotter pin holding it in place or the ones I used had a spring-loaded ball (like the retainer ball on most socket wrenches) which keeps it from falling out on its own.
Organized trail runs and most 4x4 clubs do not allow pin type clevis because they separate too easily when pulled on. Screw-in type clevis are stronger, and more secure. Either tighten the cross pin with a long Phillips screwdriver or as suggested use wire or a zip tie to secure them.
Tow straps with steel hooks on them are also not allowed.
CJ7-Tim is offline
post #32 of 53 Old 08-01-2013, 12:43 PM
XJ93
I reefed mine on with a pair of 14" pipe wrenches. I have a two others I keep inside to attach if needed. I also keep the pipe wrenches in my tool box just in case I need to remove the bumper mounted ones..you know for that one guy on the trail that has no recovery points at all.
XJ93 is offline
post #33 of 53 Old 08-01-2013, 10:01 PM
lutzke21
Don't remember where I saw it, but someone places a ring of pipe insulation (the black dense foam stuff) between the ring and the mount on both sides to eliminate the rattling.
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #34 of 53 Old 08-01-2013, 10:10 PM
bigbossd1030
Kinda like these...
http://www.quadratec.com/products/92144_900X_PG.htm
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #35 of 53 Old 08-01-2013, 11:02 PM
metalry101
Originally Posted by 87TPIYJ View Post
Why dont you just wrap the threads in electrical tape or possibly some teflon tape? That should help provide enough friction on the threads so that it will not back out. I used electrical tape on the non threaded part to keep them from rattling and it worked like a charm.
This. I just wrapped mine w/ a little teflon tape and tightened it down pretty tight. It hasn't gone anywhere since, so I'm happy with it.
'90 YJ - Squirrel powered and on 35's!
Utah Jeepcrew #26
metalry101 is offline
post #36 of 53 Old 08-02-2013, 08:23 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Originally Posted by mshows577 View Post
so i have 2 d rings in the front and 2 d rings in the back of my jeep. and they keep loosing up every few days and i actually lost on on the road the other day. i am looking for a way to make them keep from backing out. but still be able to take them off without cutting them if i ever do need to take them off. any ideas would be appriciated. and im trying to avoid anything that looks like junk like duct taping them on. (even though i do love my duct tape)
Its a Clevis. A D ring is something else. tighten them on with a screwdriver and leave it in the jeep to take them off.
Poke is offline
post #37 of 53 Old 08-02-2013, 01:23 PM
UZI4U
Originally Posted by 69moparman View Post
I guess I keep mine on because it looks cool. But I keep the bolt eyes toward the inside of the Jeep and put a bungie cord between them, with the bungie hooks in the holes in the bolts. Keeps them from rattling and unscrewing.
That's what I do as well. Never lost one yet.
MCLMM
UZI4U is offline
post #38 of 53 Old 08-02-2013, 03:33 PM
Billy
Billy's Avatar
Everything in my jeep rattles so much that a rattling D-ring is the last thing I notice rattling.
Everyone IS out to get you, if you just believe in yourself and try hard enough!
Billy is offline
post #39 of 53 Old 08-02-2013, 03:34 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Glad it worked for you
YJ 350TPI NV4500 (D60 14BFF in process)
87TPIYJ is offline
post #40 of 53 Old 08-02-2013, 04:05 PM
TSEJEEPERS
I use a rubber o ring.
Keeps it tight, and is easy to take off when needed.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #41 of 53 Old 08-03-2013, 03:11 AM
fishadventure
Thank you
fishadventure is offline
post #42 of 53 Old 08-03-2013, 06:06 AM
roadyrob
1987 YJ Wrangler
in construction we call them shackles
https://www.google.com/search?q=shac...w=1360&bih=643
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #43 of 53 Old 08-03-2013, 07:51 AM
rogerv
What about going to a 3 piece shackle ? Where I work, we are not allowed to use the 2 piece units' for the same reason the OP started this thread. With a proper keeper installed it won't come off.
rogerv is offline
post #44 of 53 Old 08-04-2013, 10:15 AM Thread Starter
mshows577
hahahhaha you and me both man
mshows577 is offline
post #45 of 53 Old 08-06-2013, 08:43 AM
XJ93
Just get some of these
XJ93 is offline
d rings , jeep
