D ring falling off - JeepForum.com
post #1 of 53 Old 07-31-2013, 10:03 AM Thread Starter
mshows577
2016 JK Wrangler
D ring falling off
so i have 2 d rings in the front and 2 d rings in the back of my jeep. and they keep loosing up every few days and i actually lost on on the road the other day. i am looking for a way to make them keep from backing out. but still be able to take them off without cutting them if i ever do need to take them off. any ideas would be appriciated. and im trying to avoid anything that looks like junk like duct taping them on. (even though i do love my duct tape)
mshows577 is offline
post #2 of 53 Old 07-31-2013, 10:07 AM
grandboost98
I use zip ties
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #3 of 53 Old 07-31-2013, 10:10 AM
bpounds
bpounds's Avatar
bpounds is online now
post #4 of 53 Old 07-31-2013, 10:17 AM
Old4X
1990 CJ7
Originally Posted by bpounds View Post
I was going to mention safety wire, but this is very close
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 53 Old 07-31-2013, 10:29 AM Thread Starter
mshows577
2016 JK Wrangler
man i feel retarted i cant believe i didnt think of that. i got a pack of zip ties in my jeep right now.
post #6 of 53 Old 07-31-2013, 10:37 AM
SeanB95YJ
I don't have them now, but did on my old XJ.... I had problems with the bolt type shackles, either loosening and falling off as you're describing, or the slightest bit of corrosion making them a bear to unscrew... so I switched to clevis pin type, which instead of a threaded bolt is basically a pin similar to a hitch pin. you can either use the type with a cotter pin holding it in place or the ones I used had a spring-loaded ball (like the retainer ball on most socket wrenches) which keeps it from falling out on its own.
bonus to these is that when you WANT to remove them, they pull out real easily, even with gloves on and don't need pliers or anything to unstick frozen threads.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #7 of 53 Old 07-31-2013, 10:39 AM
WhiteOut
WhiteOut's Avatar
Why do you need them on the outside of the Jeep on the road?
WhiteOut is offline
post #8 of 53 Old 07-31-2013, 10:45 AM Thread Starter
mshows577
2016 JK Wrangler
i dont. but it would just be easier to keep them there all the time. instead of storing them in the jeep.
post #9 of 53 Old 07-31-2013, 11:26 AM
jbolty
jbolty's Avatar
Leave them off. Every time you need to use it you need to unhook it, unscrew it, put the strap in then repeat the process. Plus they rattle.
jbolty is offline
post #10 of 53 Old 07-31-2013, 11:28 AM Thread Starter
mshows577
2016 JK Wrangler
i have never noticed the rattle, but that could be because the back of my jeep is filled with rattling tools lol. and i have a big hook on the end of my pull strap so i dont have to pull them off when i hook up to them
post #11 of 53 Old 07-31-2013, 11:29 AM
tom_sprecher
+1 and they can be stolen.
Tom
tom_sprecher is offline
post #12 of 53 Old 07-31-2013, 11:43 AM
jbolty
jbolty's Avatar
If you have a metal hook on your tow strap it's a potential death missle.
jbolty is offline
post #13 of 53 Old 07-31-2013, 11:52 AM
jsipe007
If you are dead set on leaving them on, some blue loctite might do the trick and keep the pin from backing out
jsipe007 is offline
post #14 of 53 Old 07-31-2013, 01:31 PM
NHfireLJ
NHfireLJ's Avatar
I use a crescent wrench on them to tighten the pin up very snug. never lost them yet, and not likely to be stolen unless they have a bigger wrench than mine.. I keep a spare in the box and use that to secure any straps etc to the mounted ones.
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #15 of 53 Old 07-31-2013, 01:39 PM Thread Starter
mshows577
2016 JK Wrangler
potential death missle? i have a 6000 pound strap and the hook is rated at least twice that. and the hook sets to the d ring. which is also rated at way more than 6000 lb
d rings , jeep
