Cylinders dropping out on highway - JeepForum.com
post #1 of 7 Old 09-18-2013, 04:38 PM Thread Starter
Airjordan01
Hi guys! I just bought this 92 yj. Guy before me had it 19 years well maintained. He told me when I bought it that it needed a computer. That he had replaced a bunch of parts and gave up. I bought the computer truck ran much better as it was having problems starting and I had previously had to do the key trick when it acted up. So now at one problem seems fixed I have come across another. When driving typically on the highway but not always its as if all cylinders drop out. Either from fuel or spark. These parts were replaced right before I bought it. Cap, rotor, plugs, wires, coil, crankshaft sensor. I have replaced the computer and the tips. Problem still persists! Again truck will completely cut out for a split second then continue on driving. I'm in need of answers. Thanks!
Airjordan01 is offline
post #2 of 7 Old 09-18-2013, 05:07 PM
rambo3489
I won't be much help but I would bet its spark. If the fuel is cutting out I'd think it would at least stumble a little before cutting out completely.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #3 of 7 Old 09-18-2013, 06:19 PM Thread Starter
Airjordan01
Yeah I'm going to look into the stator/camshaft sensor inside the distributor. Not sure if that was changed out. Cap wires rotor and plug definitely are new. This is a nightmare. I have no codes either or check engine light.
post #4 of 7 Old 09-19-2013, 07:47 AM Thread Starter
Airjordan01
Bump! Come on guys I need some creative ideas!
post #5 of 7 Old 09-19-2013, 08:07 AM
jeepguy85
1987 YJ Wrangler
Do your gauges cut out when the engine cuts out? If so, I would look deeper into the computer. If not, I agree this is probably a spark issue. I would look at your coil first.
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #6 of 7 Old 09-19-2013, 08:10 AM Thread Starter
Airjordan01
Gushes
I'm pretty sure the only Guatemala that affected is the rpm. It drops a little and jumps right back up. Do you mean all gauges? It is a brand new reman computer.
post #7 of 7 Old 09-19-2013, 08:19 AM
jeepguy85
1987 YJ Wrangler
Yes all gauges. I have a buddy with a 2000 ZJ that had similar issues. He had his computer rebuilt and still had issues. I convinced him to buy a new computer and have it flashed. It cleared up his issues. His issue involved gauges dropping out every time it happened. It does not sound like you are having similar issues.
crankshaft position , cylinder misfire , distributor , tips , tps
