cylinder head woes - JeepForum.com
post #1 of 4 Old 11-23-2011, 06:53 PM Thread Starter
ronfezz
cylinder head woes
picked up the head from the shop today,cracked between intake and exhaust valves seats on #4 cylinder. all the parts suppliers around here get their rebuilt heads from moores, who says they dont have any cores to rebuild which equals me not being able to get one.
you guys have any sources where i can get a rebuilt head
thanks
ronfezz is offline
post #2 of 4 Old 11-23-2011, 07:04 PM
nembudonna
Try a salvage yard or craigslist or Ebay.
nembudonna is offline
post #3 of 4 Old 11-25-2011, 10:22 AM
sptrmike
sptrmike's Avatar
try cylinder heads.com i rebuilt my engine last year and could not source oversize valves to rebuild my head. my head casting #3661 is not easy to find but they had it cost to my door was about 330.00. you have to have the same head to send back as core they pay the shipping for that up front. when i got mine i tore it down and measured every thing ,they did an exellent job.the only thing that was not good was the new viton seals they used, i started blowing smoke after the first ten miles,i went back in and swapped them out with oem style umbrella seals, felpro brand made of teflon and nylon a little more money than the plastic ones but worth it. my heap runs awsome
good luck
sptrmike is offline
post #4 of 4 Old 11-25-2011, 03:41 PM Thread Starter
ronfezz
picked up a salvage yard head today and dropped it off at the machine shop
he said it was a reman head already so i hope its ok.
i bought the felpro head set already i will call the shop and ask about whether
those valve seals are in the set. thanks for the tip.
ronfezz is offline
Slave/Master cylinder woes (yet again) Sleuthhound YJ Wrangler Technical Forum 7 07-13-2011 10:41 AM
Blown CYLINDER HEAD / HEAD GASKET JB73 TJ Wrangler Technical Forum 19 01-16-2011 01:38 AM
Slave Cylinder woes...Missing Bleeder Valve Screw xjcrwlr YJ Wrangler Technical Forum 7 01-01-2010 05:43 PM
4.0L cylinder head mod rocklee YJ Wrangler Technical Forum 5 02-25-2009 06:45 PM
Ignition cylinder woes!! Straight Six TJ Wrangler Technical Forum 6 02-26-2008 08:25 PM
