Cylender head bolts - JeepForum.com
post #1 of 7 Old 02-16-2013, 10:13 AM Thread Starter
jakesjeepmj1988
1988 MJ Comanche
Cylender head bolts
I am putting my cylender head back on and need to know what order the bolts go in and the troque specs on the bolts
jakesjeepmj1988 is offline
post #2 of 7 Old 02-16-2013, 11:22 AM
YJacob
look in a chilton manual
YJacob is offline
post #3 of 7 Old 02-16-2013, 12:41 PM
pasinbuy
You must mean what order to tighten the bolts. They go in one at a time.
A Chilton manual at any Advanced Auto store will help you a lot.
Also you are in the wrong section for your rig. This is the Yj section.
pasinbuy is offline
post #4 of 7 Old 02-17-2013, 04:04 AM
nembudonna
You start in the middle and work your way out. Left. Right. Left. Up and down.
nembudonna is offline
post #5 of 7 Old 02-17-2013, 08:45 AM Thread Starter
jakesjeepmj1988
1988 MJ Comanche
Thanks guys
post #6 of 7 Old 02-17-2013, 05:09 PM
ROWA
ROWA's Avatar
First put in all bolts and hand tighten them. Start at 80 Lbs/Ft. and work from the middle out, increases in 5 Lbs/Ft. increments until you get to 110 Lbs/Ft., on the four cylinder the #7 and on the 6 cylinder the #11 bolt is only thightend to 100 Lbs/Ft., these two bolts are on the front left side of the engine.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #7 of 7 Old 02-17-2013, 07:33 PM
tdewit
The order of the bolts going in does not matter, you should be more concerned about the order of tightening the bolts.
tdewit is offline
