Cv shaft pricing... Why such a big difference - JeepForum.com
post #1 of 27 Old 11-03-2011, 03:24 PM Thread Starter
1993sahara
Getting an AA sye installed next week n the offroad shop uses a quigley 4x4 shop driveshaft n they charge 330 for the shaft. I called quigley n they seem very nice but they use neapco greasable u joints in them. I can get a cv shaft from Carolina driveshaft with spicer u joints, greasable 208 and solid for 218. Then other shafts are well over 300. Why is this? I literally have no idea which shaft to go with now
93 Sahara 4.0, ax15, BDS 2 inch springs, MORE greasable 5/8hd shackles, Ford 8.8 rear, AA sye, Quigley cv shaft, 32" wrangler mtr with Kevlar
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
1993sahara is offline
post #2 of 27 Old 11-03-2011, 03:44 PM
Louie4
"You pass butter"
Louie4's Avatar
Maybe send Carolina driveshaft a link to the others and ask the difference or vice versa. Send the link to the higher priced ones and see what the difference is. Maybe one has thicker, beefier tubing, bigger u-joints, longer slip joint.
I know the standard non double cardan shafts are around $200 or so and the CV style are around $300 last I checked.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #3 of 27 Old 11-03-2011, 03:51 PM Thread Starter
1993sahara
I just called Carolina and asked them why they sell there cv shafts for for so much cheaper then everyone else and the reason they gave me back was that probably because they don't have the overhead like bigger companies. Their basic cv shaft starts at 188 n then the spicer ujoints r upgrades to the prices posted in the first post. Everything in there shaft is made in America she said as well
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
post #4 of 27 Old 11-03-2011, 04:17 PM
Apollo12227
You could just pay $60.00 - $100.00 to have a Cherokee front driveshaft shortened for use in the rear of your YJ. It wil bolt right up all you have t do is measure ujoint to ujoint and have a driveshaft shop shorten it.
Apollo12227 is offline
post #5 of 27 Old 11-03-2011, 04:57 PM Thread Starter
1993sahara
Cheapest I can get a xj front shaft around here is over 100$ n then plus shortening and new ujoints so that's a waste in my book
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
post #6 of 27 Old 11-03-2011, 06:19 PM Thread Starter
1993sahara
Could anyone give me info on which spicer u joint would best fit me? Greasable or solid? My jeep only has 2 5/8 in lift with 32s. My jeep is my daily driver as well
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
post #7 of 27 Old 11-03-2011, 06:28 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Or you can get a front DS from an early 80's Chevy/GMC 3/4 ton, 1ton for even less (there are about eleventy bajillion in every JY in 'Merica). It uses the same size u-joints, has a double cardigan joint and has a much thicker tube than the XJ could ever dream of. I have one under my jeep, I have helped install several under others as well. If memory serves me I paid @ $30 ish for mine.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #8 of 27 Old 11-03-2011, 07:48 PM
Apollo12227
Yeah if $100 is the cheapest they go then new is tour only option for sure. Xj driveshafts around here are a dime a dozen. I picked up 2 for $20.00... Guess it depends on where you live. I saw one for 23.00 on eBay the other day. Anyways, I paid 10.00 for mine and 60.00 to lengthen and balance for the front.
As for width? Well mine have done just fine, and my friends behind a built 350 has done just fine as well.
post #9 of 27 Old 11-03-2011, 09:00 PM Thread Starter
1993sahara
What u joints do u use
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
post #10 of 27 Old 11-03-2011, 10:09 PM
Apollo12227
I reused the ones that were on the XJ. Figured i would replace them as they need replacing. Most XJ owners use them as family vehicles, and front driveshafts operate on XJ's at near zero angle. I have put about 30K miles on my XJ driveshafts and they have held up so far. I purchased some spicer gresable ujonts for the CV portion but haven't needed them yet.
post #11 of 27 Old 11-03-2011, 11:13 PM Thread Starter
1993sahara
Gotcha. I just did alittle more research tonight and found another place called Adams driveshaft in Nevada that sells cv shafts with spicer joints for 235$
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
post #12 of 27 Old 11-04-2011, 09:40 AM
Jax89Jeeper
I have Adam's CV shafts in both front and rear. The quality is great, and no issues at all. They are another 100% made in America company.
Jax89Jeeper is offline
post #13 of 27 Old 11-04-2011, 12:35 PM
ssyj94
I just picked up a driveshaft from a local driveshaft shop Axle Exchange in fairfield nj for a very reasonable price and with a super quick lead time. Would be worth a call to get a quote.
A friend used an adam's driveshaft and it seemed fine to me. I've also used Highangle driveline in CA but the shipping takes a full 5days to my coast.
My build:
ssyj94 is offline
post #14 of 27 Old 11-04-2011, 01:02 PM
firefighter315
I've been more than happy with my Tatton. $220 out the door and received within a week of ordering. Very strong driveshaft. Another American made product and I like it that the owner, Curtis, answers the phone himself and takes your order.
http://www.jeepforum.com/forum/f256/...shafts-771913/
My YJ Build Thread
firefighter315 is offline
post #15 of 27 Old 11-04-2011, 01:11 PM
Mike
oooh you almost had it
Mike's Avatar
x2 for Tattons. I got one for the wifes xj. I've had one of his side by side with a Tom Woods unit and I would take Tattons no questions asked. great product.
Mike is offline
