CV Drive Shaft Length for 2.5" Lift? - JeepForum.com
post #1 of 6 Old 03-03-2012, 08:12 AM Thread Starter
Jims-87YJ
1987 YJ Wrangler
OK I am in the midst of deciding whether or not to pull the plug on a SYE and Drive shaft. The problem is all I have right now is a rolling chassis with a new 2" BDS Lift and 1/2" Boom Shackles and no real weight on the Chassis to get an accurate measurement of Drive shaft Length which all mfg's seem to need?
How critical is this measurement I thought that the CV drive shafts had a slip yoke on the shaft, are this designed to that close of a tolerance? Even after I get the tub and Engine mounted there will be some settling over time as the new springs break in right? So won't that further change the length?
Sorry for rambling, but why would not any YJ with a total of 2.5" of suspension lift take the same length Drive shaft?
Thanks for any input, Jim
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #2 of 6 Old 03-03-2012, 08:16 AM
MLJeeper
MLJeeper's Avatar
First off, you really should be able to get by without a SYE or a TC drop with a 2.5 inch lift. But that aside, you really need to wait till all the weight is on it to measure. If you cant wait, call Tom Woods Driveshafts, Tom Woods will answer and tell him what you are doing. He will be able to sell or tell you what you need based on his knowledge and experience building thousands of shafts for Jeeps, even if you dont buy from him. Same for any other reputable shops.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #3 of 6 Old 03-03-2012, 10:21 AM
giggityjeeper
^^ what he said.... wait till its done to measure, but you really wont need one
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #4 of 6 Old 03-03-2012, 12:43 PM
Almost a jeep
For what it's worth...... adamsdriveshaft.com, where I got mine, keeps a list of every vehicle that he makes a shaft for. I was able to give him the year and make, make and height of lift and trans (auto or manual) and which rear end you have, and he just pulled up what length that he has made for others. His product worked great for me.
94 Wrangler SE, 4.0, Auto, SYE, Hard top, 31X10.5X15, 3" Skyjacker, 8.8 w/ disc brakes. 06 Grand Cherokee stock.
Almost a jeep is offline
post #5 of 6 Old 03-03-2012, 02:42 PM
MLJeeper
MLJeeper's Avatar
Good to hear about other good vendors. Tom Woods is hardly the only one out there, Hes just a damn good one. I had just bought a front driveshaft and some***hat hit me and shoved the shaft through the trans case, literally. I called up Tom Woods just to get another one, even had insurance money and he tried not to charge me saying it shouldn't of bent, LOL. He will always get a shout out from me for that kind of customer service.
MLJeeper is offline
post #6 of 6 Old 03-03-2012, 04:14 PM Thread Starter
Jims-87YJ
1987 YJ Wrangler
Well my concern is that as it sits right now the Rear drive shaft I have only contacts the splines by like 1/2", hence my concerns. I realize the with weight on it it will be better, but I figured that if I was going to do it now is the best time before I mount anything else on, or fill with fluids. Are there different length "stock drive shafts out of curiosity? The one I have was thrown in when I picked up the axles not sure what year it came off of? Thanks again for the info.
My build thread:
cv drive shaft , cv driveshaft
Drive Shaft Length wsaxer TJ Wrangler Technical Forum 3 11-29-2010 10:46 PM
Drive Shaft Length zener6 TJ Wrangler Technical Forum 8 04-20-2009 12:49 PM
Rubicon 6-Speed Drive shaft length w/2-3" lift rudy99 TJ Wrangler Technical Forum 0 04-14-2008 08:40 AM
Drive shaft length? 90yjkrawler YJ Wrangler Technical Forum 3 11-05-2006 01:58 PM
drive shaft length for lift?? Goondock TJ Wrangler Technical Forum 1 06-06-2006 05:57 PM
