#1 | |
cutting down body lift blocks
has anyone cut down the nylon body blocks?
I'm taking the 3" blocks off my wifes jeep and I'm gonna cut them into 1" blocks(so I can get 2 -1" body lifts). I have a sawzall,angle grinder and a pnumatic cut-off tool. I think the best tool will be the cut-off tool to cut them.I'm an electrician so I know how to cut pipe straight with sawzall so I'm gonna use that knowledge to cut the blocks straight. TIA kenny
83 cj-7 258c.i., 727auto, d300, d44 front, d60 rear 92'yj 4.3(roller) tbi chevy,700r4 ,soa, 35-12.50-15 maxxis bighorns 89'yj wife's jeep 4.2l stock ,2"bl ,31-10.50-15 bfg mud terrains work smarter not harder |
#2 |
i have a 3.5" body lift (which i do not want) that i am wanting to cut down to a 1.5" or 2" when u get down tell me how it went.. and maybe some pics thata be sweet... thanx later
'88 yj wrangler 2.5L /w 3.5 black diamond suspension lift, 2" body lift, 1 1/4" shackles, detroit gearless front locker, lockright in rear, posi-lok, traction bars off, no sway, 35x12.50x15 baja claws on homemade beadlocks, 4.10 gears protected by homemade diff covers, TFI, herculined, 8000lb winch, GenRight Bumbers, BrownDog 1''MML, JB SYE, flowmaster, custom YJ dash, kicker 4" front speakers, sony explode cd player, rocker panel guards, custom SS red brake lines. |
#3 | |
How are you measuring your bodylift? The factory rubber bushing on the bottom is typically not measured when you measure the Lift pucks. Pretty sure noone made a 3.5" bodylift. 3" is the max. usually sold.
Jason T. '05 Saab 9-5 Aero: Black. Turbocharged Swedish goodness '04 WJ:Special Edition. V8, QTII, 2"BB, Bilsteins & 245/75/16" Goodyears '02 WJ:4.7L, Selec-Trac. Totalled 9-12-07. Click to hearKolak 3" exhaust sound clip http://www.cardomain.com/id/MourningWoody |
#4 |
I would put the factory finished end against the body and the end i cut against the mount. Should work ok though i would think as long as its a nice clean cut.
Your limited slip differential sucks. |
#5 |
yea I don't think it will be a problem.After I cut them I'm going to sand the cut edge to a smooth finish.
I was just wondering if anyone else did this,and what tool they used. ![]()
#6 |
I dont see a problem cutting it down, just be sure you keep it good and square. Personally I would use a woodworking miter saw with a wood blade. The wood blade will cut the nylon/plastic with no problem. I would set up stop blocks on the saw to ensure that each nylon spacer is the exact same length, also I would clamp down the spacers to keep my fingers away from the blade as you are dealing with some pretty smalll pieces. Additionally you will only get a part of a 2nd lift kit as there is alot of hardware that comes in the kit. another thing you will probably run into is that the bolts will be too long and will have to be replaced or cut down.
Rattletrap |
#7 |
Did it. It was really easy. You could just cut straight down the seam in the middle of the puck, and have (2) 1.5" BLs. That is what I did.
92 YJ, 4.0L, 5-speed, 35" Goodyear MTR's |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
