cutting cj top to fit yj - JeepForum.com
post #1 of 11 Old 08-23-2011, 01:19 PM Thread Starter
eaelliott5
I just got a hardtop off of an '83 cj for my yj. The front along the windshield does not quite line up because of the different roll bar causing it to not sit flush along the tub of the jeep. I was wondering if anyone could tell me exactly where to cut before I just go wildly hacking away at the top. I'm not sure if I can just cut around the roll bar mounts or if I will have to shave a bit off the outside of the top where it sits on the outside windshield.
thanks in advance
eaelliott5 is offline
post #2 of 11 Old 08-23-2011, 01:24 PM
grandboost98
there should be no cutting involved if its a cj7 top. thats what i had on mine with no modification
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #3 of 11 Old 08-23-2011, 02:05 PM
Alfons
^^I agree. If the soft top rail is still on the windshield or if the windshield isn't lined up the way it needs to be, you won't get any hard top on.
Alfons is offline
post #4 of 11 Old 08-23-2011, 02:06 PM
timatoe
timatoe's Avatar
The only time I've ever heard of any trimming necessary was around the rear door area and I don't remember why that had to happen. Shouldn't be any need for cutting. Maybe take some pics and host them on photobucket and post the "img" links here, then we can give better advice.
timatoe is offline
post #5 of 11 Old 08-23-2011, 02:16 PM
Louie4
I have a CJ-7 hardtop on my YJ right now and the PO did notch the corners to fit the roll bar attaching the rear cage to the windshield. I can take some pics if you'd like. It looks like he had to do it to keep it from hitting the roll bar.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 11 Old 08-23-2011, 02:40 PM Thread Starter
eaelliott5
All of the soft top hardware is off the jeep, there is about a 1/4-1/2 inch gap inside between the top and top of windshield due to the roll bar. This is causing about the same size gap on the tub right by the doors. Outside it seems to rest fine where it needs to be. I've seen on some other threads that sometimes they need to be cut so I didn't know if who had already done it could tell me exactly where to cut. Also I'm in the army and live in the barracks so tools are limited. Any cheap ideas there?
post #7 of 11 Old 08-23-2011, 02:52 PM
GRYDE001
I had to do this as well with a CJ7 top I bought a few months ago. It was hitting the roll bar "spreader bars" where they attach to the top of the windshield. I just used an angle grinder with a cutoff wheel to notch the INSIDE of the two channels of the hardtop. I'll try to get a pic later if you need one.
""Leave it stock, it will live longer. Just understand that its never gonna be as fast as a minivan""
GRYDE001 is offline
post #8 of 11 Old 08-23-2011, 03:38 PM
danlee
1987 YJ Wrangler
I ended up loosing my roll bar where it fastenens to the windsheild frame, I also loosened up the adjusters as well. Once my top was on and in place I tightened everything up.
danlee is offline
post #9 of 11 Old 08-23-2011, 03:59 PM
nzpete
Yes, you may have to notch the area where the roll bar connects to the windshield frame.
To me, RC is kind of the Harbor Freight of springs. Sometimes you get a good deal and sometimes you don't.
nzpete is offline
post #10 of 11 Old 08-23-2011, 08:35 PM
yellow2kgt
I had to notch my CJ top as well. Sorry, I don't have any pics as the top is in the basement for the summer. However, it should be fairly obvious. I set the top on and marked where I needed to cut. If I remember correctly it was not much maybe 3/8" or less just in the corners to clear the sport bars. I just made my marks, took the top off and laid it upside down in the yard and took a cut off wheel to it. It should only take a few minutes and if you marked correctly and smoothed the cut it will look factory.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #11 of 11 Old 08-26-2011, 10:56 PM Thread Starter
eaelliott5
Got it done, cut the inside and still had to shave about an 1/8 of an inch off the outside where it rests on the windshield to make it fit. Hopefully that doesn't cause problems with the doors.
Thanks for the advice,
Eric
cj , hardtop , YJ
89 yj cutting out lilmike386 YJ Wrangler Technical Forum 4 09-07-2009 02:24 PM
Cutting MY LTBS? help with tire cutting Tacoma750 TJ Wrangler Technical Forum 3 03-29-2007 09:39 PM
Cutting the Tub.....what to use?? None TJ Wrangler Technical Forum 15 03-02-2007 03:19 PM
cutting BL???? RnEmOvr TJ Wrangler Technical Forum 6 11-07-2005 11:02 AM
cutting out StuckInMud94 YJ Wrangler Technical Forum 2 04-05-2005 01:39 PM
