cutting brake lines - JeepForum.com
post #1 of 10 Old 06-21-2010, 12:20 PM Thread Starter
chicalibro3
cutting brake lines
okay so i totally can't get my brake lines off! I used like three different types of vise grip, and i still can't get it off. I've resorted to cutting the lines. I'm thinking about using my dremel tool to cut the lines. I know that there are line cutters but i don't think they will fit. Do you guys think this is a bad idea. i really don't want to botch this cause i need my car by wednesday.
chicalibro3 is offline
post #2 of 10 Old 06-21-2010, 12:30 PM
jbolty
jbolty's Avatar
what exactly is your project? are you replacing wheel cylinders, calipers, master?
jbolty is offline
post #3 of 10 Old 06-21-2010, 12:59 PM Thread Starter
chicalibro3
oops! sorry i forgot to carify. I'm trying to put longer brake lines on the front of my Jeep. I put the lift on and now all that is keeping me from wheeling is the length of my brake lines. I've been trying to get the rubber lines off and the flare nut on the hard brake line both driver and passenger side are rounded off and i can't get them off.
so i'm thinking about cutting the hard line re-flaring. Is there a better way of doing this?
post #4 of 10 Old 06-21-2010, 01:24 PM Thread Starter
chicalibro3
Or do you think i should just buy some new line and replace it?
post #5 of 10 Old 06-21-2010, 01:39 PM
jbolty
jbolty's Avatar
I replaced all the hard lines for about $50 and 2-3 hours work.
Or you can cut the existing back and re-flare it but then it might be too short and it is for sure an awkward place to work.
jbolty is offline
post #6 of 10 Old 06-21-2010, 02:01 PM Thread Starter
chicalibro3
I might as well do that. Thanks JBOLTY, I love your jeep btw.
post #7 of 10 Old 06-21-2010, 02:05 PM
EABiker
If you use a saw or cutoff wheel to cut lines, rather than a tubing cutter, you will get fine metal particles in your line and brake fluid. These particles will cause rapid wear and possibly failure once they get into the wheel cylinder or caliper!
EABiker is offline
post #8 of 10 Old 06-21-2010, 02:06 PM
1 ton yj
1 ton yj's Avatar
Go to Autozone and rent a flaring tool. It'll come with a line cutter. Do not try to use anything but a line cutter. Buy a new male 3/16 brake end (maybe a dollar?) and install it with a new flare. Practice double-flaring on some scrap before trying on your line.
Oh and you need line wrenches to work on brake fittings because they are soft brass. Regular wrenches will round them off right away as you have found out.
1 ton yj is offline
post #9 of 10 Old 06-21-2010, 02:20 PM Thread Starter
chicalibro3
Thanks guys. I'll let u guys know how it goes.
post #10 of 10 Old 06-21-2010, 09:46 PM Thread Starter
chicalibro3
Alright, just finished. Took me about 4 hours but I got it done. I just cut the old lines (with a pipe/line cutter) and flared them. What took me the longest was bleeding the brakes. I left out two washers that go between the caliper and the block of the new line. That caused too much pressure I guess, because fluid sprayed out at the joint of the block and the line. Put them back on and I think I'm good. Tested the brakes around he neighborhood and they seemed fine. I'll do some bigger streets tomorrow.
open using cutting brake mikesbeachhut TJ Wrangler Technical Forum 4 10-04-2009 10:18 AM
After replacing calipers and rubber brake lines, my brake is still stuck! Dmcastino TJ Wrangler Technical Forum 23 06-26-2009 12:21 AM
Hard Brake lines(not soft lines) Nonya TJ Wrangler Technical Forum 0 09-04-2007 07:33 PM
Stock brake lines don't bolt up to Van's Big Brake kit Red_ TJ Wrangler Technical Forum 6 06-17-2007 11:11 PM
8.8 swap brake problems. How did you run your brake lines? quitelifted TJ Wrangler Technical Forum 5 10-19-2006 10:16 AM
