Quantcast Custom Dash Build - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Custom Dash Build
Old 02-04-2008, 06:22 PM   #16
coyote_94yj
Originally Posted by rustywrangler View Post
That is one sexy dash you got there man. DO you have a cost estimate on the end result with gauges???
$550 for all electrical gauges from summit racing. About $100 - $130 for all the aluminum, hinges, screws and nutserts. And then you have the wire and painless connectors which came to about $60.
So about $710 - $740
Originally Posted by scooter18155 View Post
nice dash there just 1 ? though why go with a push button start instead of normal ignition in column?
I'm military and most military vehicles are combat start (eg. no keys just push button or switch) so that is what I'm sort of used to. 95% of the time the jeep is on base. I do have a hidden master switch to deter thieves.
It is so nice at the end of the day to just get in the jeep snap the belt and go click, click, boom and drive away. Especially if the doors are off. 2 seconds and I'm rolling.
Chris
coyote_94yj is offline   Reply With Quote
Old 02-04-2008, 06:53 PM   #17
Joe Dillard
Free clues & suggestions
Joe Dillard's Avatar
I dig it! Nice to see somebody do something unique. It came out very well!
Joe Dillard is offline   Reply With Quote
Old 02-04-2008, 08:04 PM   #18
1 ton yj
Very nice, I like the finish on the aluminum.
1 ton yj is offline   Reply With Quote
Old 02-04-2008, 09:13 PM   #19
Barrio
no need for a glove box?
im thinkin of doing bascily the samething but having a big,lockible glove box
www.offroadjunkies.net
www.pgh-offroad.com
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline   Reply With Quote
Old 02-04-2008, 09:15 PM   #20
docneon
You had me UNTIL hello
docneon's Avatar
1987 YJ Wrangler
Originally Posted by coyote_94yj View Post
I'm in the middle of a frame off right now but I have a sweet idea in my head and I think it will work.
Basically what I plan on doing is running some ducting from the heater box where the old defroster hooked up to the flat area where the windshield meets the tub with the rubber padding in between. I'm going to cut a oblong hole on the tub side, and in the rubber to match and then in the windshield frame so that air will fill up the entire windshield frame. The rubber in between will act as a gasket between the 2. Next I will cut some long holes in the windshield frame on the flat area where the window is. I am going to use one or 2 of these as the vents.
I'm going to cut them off to what ever length looks good and angle it just a bit towards the window. I'll weld the ends closed and screw it to the windshield frame. The cool thing about this (I think) is the entire windshield frame gets heat and you can put vents on the bottom and the top, or even on the sides.
I don't know yet how it will all play out. So far it is only in my head and I haven't laid anything out. What do you think?
Chris
I've never had a CJ, but IIRC they had the defroster go through the tub and into the windshield frame then exit the base of the frame into ducting. I've read a couple write-up on using a CJ dash and people ahve modified thier windshield frame to mimic the CJs.
I think you are right on track and it should work out great
Originally Posted by Bhelliom
I assumed this thread was going to be something completely different.
I was sorely mistaken
l _____
/l ,[_\_\],
l---L –[]lllllll[]-
()_) ()_)
---o-)_)
docneon is offline   Reply With Quote
Old 02-04-2008, 09:46 PM   #21
coyote_94yj
See the thing I was thinking when I did this was if I decide to later I can just trim off the passenger side and a tuffy glove box will bolt right up.
Sweet...Good to know. Thanks. Now if I can just get my jeep back together and finish it off.
EDIT: It is never really finished!!!
Chris
Old 02-05-2008, 12:04 AM   #22
docneon
docneon's Avatar
1987 YJ Wrangler
Chris
Isn't that the truth!!!!!!!!
l _____
/l ,[_\_\],
l---L –[]lllllll[]-
()_) ()_)
---o-)_)
Old 02-05-2008, 12:10 AM   #23
Barrio
true now that you got it in you can fit what you want in their, didnt think of that
www.pgh-offroad.com
Old 02-05-2008, 07:40 AM   #24
1 ton yj
An ammo can frenched into the passengers side of the dash would look really cool and you could probably make it lockable.
Old 02-05-2008, 08:02 AM   #25
Alacran
Chris
Great job on the new dash! After looking at your idea for the defroster I have an observation. I could be wrong but I don't think that it's going to work exactly as you envision. The warm air will tend to escape from the holes closest to the source so that by the time it gets to the center of the windshield there will be little or no warm air. I like your thinking though, it's always nice to see someone try something new. If you do decide to try this I'd be very intersted to see how it works out.
Alacran is offline   Reply With Quote
Old 02-05-2008, 09:20 AM   #26
coyote_94yj
That thought crossed my mind last night so I got to thinking if I put maybe 2 or 3 small ones away from the inlet on the bottom and 2 long ones on top it might work. I might have to find a donor windshield frame and try it out before I start the operation on my jeep.
Chris
Old 02-05-2008, 11:59 AM   #27
ChiliPalmer
Bacon Ends & Pieces
ChiliPalmer's Avatar
Have you thought of just drilling holes in the windshield? Similar to Alacran's thoughts, it looks to me like there is simply too many holes in that shelf bracket. If there were less holes it would probably work but as is I think too much air is going to escape before flows to both sides. By drilling holes you could kind of control where the air flows, you could probably find an insert to put in the holes to make them look better.
If you want to help the sport of offroading visit the EnviroBeat Forum!
Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team!
ChiliPalmer is offline   Reply With Quote
Old 02-05-2008, 02:51 PM   #28
coyote_94yj
I'll consider the hole drilling idea but I think I'm going to find a donor windshield frame and try it with the shelf brackets.
Old 02-05-2008, 04:37 PM   #29
ChiliPalmer
Bacon Ends & Pieces
Roger that and good idea on the extra frame - let us know how it turns out...
Old 02-05-2008, 04:57 PM   #30
wb2510
On my dash build I drilled 1/4 to 3/16 holes along the top of the center section of the square stock that is the sub frame for the new dash. The square stock is butted up to the heater duct where a hole was cut the shape of the duct plenty of defrost flow and looks pretty clean.
wb2510 Late Jeep Club #3
1994 YJ, 2.5L, 5 speed
The rest of the family:
2006 KJ Liberty
2008 JK Wrangler Unlimited X
wb2510 is offline   Reply With Quote
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
