Quantcast Custom dash is almost done - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Custom dash is almost done
Old 10-30-2006, 01:56 PM   #1
Mr. Tobes
A while ago, I started on a custom dash for my 91 YJ. It has taken alot longer than I thought it would doue to money and time to work on it, but it is almost done!! Just though I would show it off. (the blank hole is hoing to be an oil pres. gauge. Summit sent me 2 water temp gauges)
Mr. Tobes is offline   Reply With Quote
Old 10-30-2006, 02:00 PM   #2
BIGWILL78
Very nice, clean looking install. Can't wait to see it finished. Did you purchase that dash or make it yourself? Either way, very nice!
BIGWILL78 is offline   Reply With Quote
Old 10-30-2006, 02:03 PM   #3
mississippi_xj
I like it.... A little shiny though
-scotty
98 TJ 4.0 (Geared and locked on 2" coils and 33x10.50's), Former YJ/XJ/WRX Builder...
Contribute to my YJ spring rate info thread!
mississippi_xj is offline   Reply With Quote
Old 10-30-2006, 02:07 PM   #4
UCF YJ'r
look! you yj is going 25mph in the garage!!!!
UCF YJ'r is offline   Reply With Quote
Old 10-30-2006, 02:09 PM   #5
bobbert350
looks good how much did all that cost
bobbert350 is offline   Reply With Quote
Old 10-30-2006, 02:30 PM   #6
Mr. Tobes
It only cost $60. I live not too far form a fab shop. They made it for me out of some of their scrap (which explains the scratch on the lower right side). I was thinking about powder coating it black though, cause like mississippi_xj said, it is shiny and will likely be unbearable with the reflection.
Old 10-30-2006, 02:44 PM   #7
Psyker
Big thanks for posting that, i was considering several dash options including tread plate, now i have a visual of what it would look like.
Call Sign: KF4ZHT
'96 Green XJ SE - I6, AX15, NP231, 2.5" Lift
'90 White YJ - 4 squirrels spinning a toothpick (i4 w/ax5) - WIP
Psyker is offline   Reply With Quote
Old 10-30-2006, 03:20 PM   #8
FarrellX
deffinatley powder coat that black. something i would consider doing in mine given the extra time and money. love diamond plate stuff.
FarrellX is offline   Reply With Quote
Old 10-30-2006, 03:31 PM   #9
OhioYJ
Looks good, why is your shifter backwards in those pictures (pointing towards the dash)?
95 YJ: SOA, locked 44, locked 8.8, 37s, beadlocks, OBA, winch, and a few other things. [URL=http://www.cdmfabrication.com/aboutmel.html]My Build-Up Post[/URL] -- [URL=http://www.cdmfabrication.com/kbl.html]SWB FAQ[/URL] -- Mike
OhioYJ is offline   Reply With Quote
Old 10-30-2006, 03:41 PM   #10
bobbert350
i want that now..on the bottom if its not bent at a 90 degree angle or whatever make sure u put something like some rubber on there just incase ur knee hits it..u dont want to get cut from a pretty sharp edge
Old 10-30-2006, 03:47 PM   #11
flame0086
I'm pretty sure it is not attached to the tranny right now. You can see there is a big whole in the floor next to it.
100 mpg!! Western Washington Univeristy X-Prize Team http://wwuxprize.blogspot.com/
Support Search and Rescue
Get Lost
flame0086 is offline   Reply With Quote
Old 10-30-2006, 04:10 PM   #12
mississippi_xj
You could make it all "swirley" with a wire wheel on the angle grinder... It would knock down some of the glare and might look good.....
-scotty
Old 10-30-2006, 04:11 PM   #13
toates89
1989 XJ Cherokee
what is with the no holes for speakers i would throw some 6x9s or somthing
toates89 is offline   Reply With Quote
Old 10-30-2006, 04:15 PM   #14
bobbert350
i say keep it shinny if u like it...and if u dont like it shiny dont look
Old 10-30-2006, 04:31 PM   #15
Mr. Tobes
The dash isn't completely done yet, so that is why there aren't any holes for speakers, etc...
The shifter is backwards because the rig has a 4" body lift on it. The shifter would hit the edge of the sheetmetal on the floor and I would bve able to get it into 2nd, 4th, or Reverse. Just another thing I haven't gotten to yet. In fact, for that "big hole", I am also going to make a cover for that out of diamond plate as well. I will post the pics as soon as I have time to do it.
Glock Forum
