#1 | ||
custom console build
Unlimited Length YJ "Sasquatch" Build Thread Renix 4.0 AW4 swap with awshifter = DONE custom console flatdash |
#2 |
Got my eye on you.....
![]() Join Date: Apr 2005
Looks good so far. Is this going to be a locking setup as well?
Congenital Heart Defects are a reality for me. Both of my children have one. Please read up and become aware!!!!!! Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 |
#3 |
oo thats nice. i had to rip mine out because the heat from the tranny melted what ever was in there, it also didn't have a lock, and needed to take the carpet out. so i'm hoping to build something like this as well.
#4 |
rusty,
yes it's going to lock. i just need to weld in a small piece of angle in the front of the storage compartment and then drill a hole in the lid for a cam lock (like $5 from ACE).
#5 |
woah, that's turning out nicely... and i'm a fan of that dash, too.
-- 1990 YJ, 4.2 Manual, nuttered, vac-hose minimum -- my name is Josh -- my jeep's name is MacGyver -- I make stuff for a living -- "newYJfan"... whoops, didn't think about a good username |
#6 |
I am a fan of that dash as well can you post some more pics of it please
#7 |
pictures of the dash can be found in my dash thread (link in sig). it's the same now as it was then, except now it's all wired up and has a layer of flat black on it.
#8 |
it looks good, do you weld outside? the kraft paper insulation is very flamable, tha acetone is also, that must be why you have the big extinguisher on the bench.
#9 |
It's true, i weld dangerously. should have some more updated pics later tonight
#10 |
![]() so first i welded on some hinges ($3.50 from fred meyer) ![]() then i bent up some 3/8" rod to make a handle ![]() then i cut out the holes for the cup holders. i didn't want to spend $20 on a hole saw so i used the cutoff wheel on the dremel to get close, then ground the rest of it with a die grinder. ![]() then i drilled some holes and cut out a rectangle for the shifter to sit in. ![]() i then welded in a piece of 3/8" rod for the lock to grab onto when in the locked position. ![]() Here's the lock mounted into the lid. ![]() ![]() and here it is done. There's still plenty of room to mount a stereo in front of the shifter and to the side i will eventually be adding winch controls and a rocker for the torque converter lockup. all i need to do now is make a couple of brackets to hold it into the jeep.
#11 |
That is some really nice work man
It seemed like a good idea at the time... |
#12 |
Looks really good man. Can you build me one?
#13 |
ME TOO!
#14 |
That looks great! Being able to control an automatic tranny would be the best of both worlds.
Black '91 YJ, pretty much stock for now. In the process of an engine rebuild. |
#15 |
Go Kings Go!
Great job! that thing looks awesome.
That shifter looks like its from an 80's racing arcade game.
95 Black YJ *Build Thread* 2.5L, 4.5" RE springs, MORE hoops 1" BL, 35" KM2's, Tube Fenders, Full Cage, D30 Aussie, TeraLow 4:1, HF 8K Winch Herculiner, Warn steering & Gas Tank skids, LED tail lights, TJ corners, Rock Sliders, Ford 8.8, JCR OTK Steering |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| custom overhead console | JVona | Wrangler General Discussion | 9 | 02-24-2009 10:10 PM |
| custom overhead console | JVona | TJ Technical Forum | 2 | 02-23-2009 07:55 PM |
| Looking for custom overhead console | machine0020 | TJ Technical Forum | 6 | 02-11-2009 07:02 PM |
| Custom console/dash | biggreentj | YJ Technical Forum | 3 | 07-20-2006 09:37 AM |
| My CNC'd custom overhead console! | Gmachine | TJ Technical Forum | 2 | 03-02-2005 10:17 PM |
The time now is 07:29 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
