Currie Dana 44 axle swap - JeepForum.com
post #1 of 29 Old 06-13-2010, 09:35 PM Thread Starter
montec
hey all, i apologize in advance if this has already been asked, but i searched the forum and couldn't find anything.
i am in the process of swapping my stock axles for Currie built Dana 44's front and rear. these are to my understanding TJ rubicon axles that they have kept the same width and beefed up the tubes and inner C's, e.t.c. i was told they would bolt in and i could reuse the stock Dana 30 outer C's and steering components. i have a 5" Alcan spring under lift with 1" shackles. i also have a dropped pitman arm installed. the problem is the stock steering drag link hits the diff cover before i get to full turn left or right. it also contacts the springs before i can get to full droop. i am also afraid the dropped pitman arm is going to make contact with the top of my diff housing when i flex the suspension. i am not sure what my options are to fix this. do i need new steering knuckles? if i need new stuff, please let me know how and where i can get it. has anyone swapped in these axles before? i appreciate the help.
montec is offline
post #2 of 29 Old 06-13-2010, 10:01 PM
Unii
maybe a tie rod flip? i think you can lose the DP if you do it. but i have no experience with the currie 44
Unii is offline
post #3 of 29 Old 06-14-2010, 07:12 PM Thread Starter
montec
is a tie rod flip the same as a high steer kit? did you have a particular manufacturer in mind or is it something i can do myself? i have began the search for a high steer kit but i am not sure what to look for as far as strength and quality. i want it to remain safe to drive at highway speeds. thanks for the help.
montec is offline
post #4 of 29 Old 06-14-2010, 08:08 PM
TSEJEEPERS
Did you order these axles from Currie or are they second hand?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #5 of 29 Old 06-14-2010, 08:24 PM Thread Starter
montec
i ordered them through 4 wheelparts... it was cheaper than straight through Currie. i did call Currie this morning and asked them for help. they said that i could dent in the cover enough for the rod to clear. however, it came with an ARB cover so i don't think that's going to happen. AND, it doesn't address the fact that it is also contacting my springs before full droop. he also suggested a high steer kit and gave me one example. this particular kit utilizes the dana 30 outer C's and you grind, drill, and tap them to accept the new arms. i am wondering now if that comprimises strength or if it is better to be looking at just upgrading to 44 outers. of course that seems to have its share of issues too. i am not sure which is the best way to go overall and was hoping someone has been down this road before...
montec is offline
post #6 of 29 Old 06-14-2010, 08:29 PM
Unii
a tie rod flip isnt the same as high steer from what i understand, go look for "go-for-it" products they are the leader in TRFs from what ive seen...
Unii is offline
post #7 of 29 Old 06-14-2010, 08:36 PM
TSEJEEPERS
I would go with the kit Currie suggested.
In order to change to 44 outers you would also have to grind the Cs off and replace them with 44 Cs.
The Dana 30 Cs will not accept the Dana 44 ball joints. I do not think that would fix your problem unless you went high steer with the 44 outers, which would put you right back to where you are now.
Another option might be to use a standard diff cover.
post #8 of 29 Old 06-14-2010, 09:41 PM Thread Starter
montec
good info to know. i was under the impression this axle would accept 30 OR 44 outers. i will have to dig deeper into my high steer options or this tie rod flip idea. has anyone used one of these kits?
montec is offline
post #9 of 29 Old 06-15-2010, 08:07 AM
TSEJEEPERS
Not unless Currie has some type of aftermarket 44 outers that would work.
The ball joints on every 44 I have seen are pressed into the steering knuckle then bolted on the Cs.
The 30 ball joints are pressed on the Cs then the steering knuckle is bolted on.
post #10 of 29 Old 06-15-2010, 06:10 PM Thread Starter
montec
i better check with Currie on that. i'm guessing you are right.
now you have me thinking... is that another option? i have been looking at kits that modify the existing knuckles, does the aftermarket make new high steer knuckles in the Dana 30 style?
montec is offline
post #11 of 29 Old 06-15-2010, 07:29 PM
cheapjeep71
You can buy a high steer kit for a Dana 30 @ 4WD Hardware or Quadratec. They are around $500.(not to cheap!)
cheapjeep71 is offline
post #12 of 29 Old 06-15-2010, 10:15 PM Thread Starter
montec
way more than i want to spend! but if i need to... that's why i am asking the questions. if i have to invest i want to make sure i am getting the right setup. i am hoping you guys will show me what all my options are! has anybody else had this problem?
montec is offline
post #13 of 29 Old 06-18-2010, 03:25 PM Thread Starter
montec
surely more people have ran into this problem and fixed it. i am guessing when you add heavy duty steering rods you up the chances of hitting on the differential cover. i am going to do a mock flip today with my stock rods and see if it will clear the cover...
montec is offline
post #14 of 29 Old 06-18-2010, 03:33 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
just out of curiosity why did you swap your hp 30 out for a lp 44(you said it was a rubi)?
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #15 of 29 Old 06-18-2010, 08:14 PM Thread Starter
montec
i wanted to go with a 5.38 gear and it hasn't been available for the 30.
montec is offline
Dana 30 to Dana 44 axle swap jjbtj TJ Wrangler Technical Forum 31 02-25-2014 05:38 PM
Dana 44 axle swap from a ZJ gunner_woody TJ Wrangler Technical Forum 10 01-08-2013 09:35 PM
dana 44 axle swap bigsquat YJ Wrangler Technical Forum 24 09-19-2008 09:14 PM
How much $$$ for an Axle swap, dana 44 or 8.8? JeepinYahoo TJ Wrangler Technical Forum 28 07-24-2006 11:03 AM
axle swap dana 44 to YJ BadAssYJ YJ Wrangler Technical Forum 6 02-24-2006 10:05 AM
