Curious about this.... - JeepForum.com
post #1 of 8 Old 03-27-2009, 10:48 AM Thread Starter
bryris
If I put the transfer case to N, then put the transmission into gear and release the clutch, are the internals of the transmission rotating as they would if I was actually moving? IOW, is the output shaft rotating at a speed commensurate with normal driving even though the transfer case's N status is not transmitting the torque to the wheels?
1995 YJ Sahara
bryris is offline
post #2 of 8 Old 03-27-2009, 11:14 AM
buckshot500
If your engine is running, then yes.
This is also the way to flat tow a manual YJ. Trans in 1st. or reverse, & transfer case in neutral.
buckshot500 is offline
post #3 of 8 Old 03-27-2009, 11:17 AM
95greenrio
The transmission will still do exactly as it would if the t-case was in any other position, with the case in neutral the input shaft is disconnected from the main shaft.
1995 YJ Rio Grand - work in progress
95greenrio is offline
post #4 of 8 Old 03-27-2009, 11:44 AM
CreepyCrawler95
so can u drive with tcase in neutral then on road and be perfectly fine, ive alays had mine in 2hi would it make a big differance?
CreepyCrawler95 is offline
post #5 of 8 Old 03-27-2009, 11:46 AM
Levinz11
If the case was in neutral no you couldn'y "drive". You could be towed.
PLEASE DEPOSIT $.75
Levinz11 is offline
post #6 of 8 Old 03-27-2009, 11:50 AM
Mark05059
It wouldnt make any difference if where you were going was constantly down hill (both ways) basically with the transfer case in neutral it would be like your engine was on and nothing inbetween the axles...
in other words your not putting any power to the ground... you would have to be in 2HI or 4HI or 4LO to go anywhere under power
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #7 of 8 Old 03-27-2009, 12:26 PM Thread Starter
bryris
I wonder if it would idle in fifth gear with the tcase in N, since there is no resistance on the output shaft.
Useless experiment, just curious.
1995 YJ Sahara
bryris is offline
post #8 of 8 Old 03-27-2009, 12:29 PM
timatoe
timatoe's Avatar
I'd say yes, as there's virtually zero torque load on the engine in that case.
timatoe is offline
Just curious will it last ToddS76 TJ Wrangler Technical Forum 4 05-31-2009 10:20 PM
Curious about POR-15 USCGTWEET TJ Wrangler Technical Forum 7 09-08-2008 12:23 AM
Just curious... djfuzzy TJ Wrangler Technical Forum 9 03-30-2008 02:56 PM
Curious as to how much I should ask for my YJ leon23 YJ Wrangler Technical Forum 7 04-13-2007 09:30 AM
SE Curious SpitNine TJ Wrangler Technical Forum 10 08-17-2006 08:30 PM
