Cummins 4bt swap - JeepForum.com
post #1 of 22 Old 11-03-2010, 07:17 PM Thread Starter
Mudmouse990
Cummins 4bt swap
im starting to plan a cummins 4bt swap into my 90 yj 2.5l. To me this seems like the best way to go for me. Im gona find a pre 98 engine so i wont have to deal with the computers ill get the thread going as soon i get the ball rolling any input?
Mudmouse990 is offline
post #2 of 22 Old 11-03-2010, 07:42 PM
youngYJ95
Hit up 4btswaps.com for any questions they have a lot of jeep builds with the 4bt in them
[Originally posted by rulppa: But no, there is no change is power.. and my arse-dyno is pretty accurate]
youngYJ95 is offline
post #3 of 22 Old 11-03-2010, 08:34 PM
Krochus
With a dry weight of over 700lbs a front axle swap is gonna pretty much be mandatory
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline
post #4 of 22 Old 11-04-2010, 04:00 AM
dodger889
A 4bt does not weigh over 700 lbs try just a little more than 475 lbs Which is about the same as a I6 engine. Now you might be thinking of the cummins 5.9 then you are talking about the 700lbs.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #5 of 22 Old 11-04-2010, 05:36 AM
Krochus
Have you seen a 4bt? Do you google before just guessing at numbers?
It does in fact weigh over 700 minus flywheel. The 5.9 weighs right at a cool grand.
That's why the original 2wd dodge diesel trucks went through front end parts like crazy. I have a 4bt sitting in a breadtruck in my back yard and I don't concider it a feasable canadate for a jeep.
4bt swaps.com FAQ
--Not every vehicle was meant to have a 4BT, although almost everyone can fit it I would be concerned with weight. Dry the motor specs in around 750+ lbs, they were notorious for wearing out the P30 Chassis front ends due to weight. So a honda civic is not a good candidate for the swap. Know what your vehicle's front end is rated for weight wise and make the safe decision to beef up components or stay away from me on the road.
Cummins shop manual
From the Cummins Shop Manual
Section E- Engine Identification
Page E-5
Engine weight
Dry, less flywheel and electrical components
4B3.9, 679 pounds 4BT3.9, 705 pounds 4BTA3.9, 725 pounds
Krochus is offline
post #6 of 22 Old 11-04-2010, 07:38 AM
YJay92
i think it a great idea. there are a lot of jeeps that have done this already. i'm considering this swap myself. i'm going to upgrade my axles to a d60 and 14 bolt. 4btswaps.com is an amazing site. good luck and i'll be watching for your build
1992 YJ, 4.0, auto, HP D30 w/TJ chromolys, 8.8 LSD, 4.10s, AA SYE, Tom Woods shaft, 5" lift, 35" MTZ's, 12k winch, Mark VIII fan, 136 amp alternator, TJ flares, custom snorkel and rock rails, no track bars or sway bar
YJay92 is offline
post #7 of 22 Old 11-04-2010, 08:04 AM
mdubs
Does it run? If so, is it for sale?
Originally Posted by linusb View Post
Success required considerable profanity.
mdubs is offline
post #8 of 22 Old 11-04-2010, 10:13 AM
Krochus
Did wHen parked and no
Krochus is offline
post #9 of 22 Old 11-04-2010, 10:25 AM
mdubs
You can't blame me for trying
mdubs is offline
post #10 of 22 Old 01-22-2012, 12:51 PM
jeeper1987
1987 YJ Wrangler
Watching this
jeeper1987 is offline
post #11 of 22 Old 01-22-2012, 01:17 PM
WakeDoctor
^ Keep us updated
WakeDoctor is offline
post #12 of 22 Old 01-22-2012, 04:01 PM
SDGBASSE
Originally Posted by WakeDoctor
^ Keep us updated
^^^^Just got that one, Rolf.
Originally Posted by ZeroGravity View Post
I didn't click the link because it says "power probe" in the url.
SDGBASSE is offline
post #13 of 22 Old 01-27-2012, 09:44 AM
fex1221
I've been toying with the idea myself. I know you have to change out the entire drivetrain to handle the extra torque and then upgrade your front suspension to handle the extra weight. I agree it's not for every vehicle but it's either a 4.0L or a 4bt and the 4bt gets better mileage and from what I understand more torque if you put a twin turbo on it(this info is just from word of mouth by other jeepers that say they've seen both) also it would be pretty cool to roll black smoke in a jeep lol. I'll be watching your thread
Go big or go home.
fex1221 is offline
post #14 of 22 Old 01-27-2012, 10:10 AM
twiisted71
Actually there are quite a few who just swapped in the 4BT. But I think they were just going for the economy, cool factor, and reliability. I am building mine with those goals plus wanting to be able to off-road it and not be in constant fear of crunching something, so yes its getting the "full meal deal"
twiisted71 is offline
post #15 of 22 Old 01-27-2012, 10:32 AM
jeepwrangler89
Thinking of the same swap for my 2.5L yj. Keep us posted!
jeepwrangler89 is offline
4B Cummins swap in 92 YJ ghiradelli777 YJ Wrangler Technical Forum 7 10-17-2012 03:19 PM
Cummins 4BT diesel / TH400 swap thegrimlinyj YJ Wrangler Technical Forum 11 12-09-2011 07:55 AM
Cummins 4bt diesel swap 1952m38a1 TJ Wrangler Technical Forum 5 12-08-2011 11:43 PM
Cummins (or any?) Deisel engine swap in a TJ? loudog3114 TJ Wrangler Technical Forum 6 10-24-2004 10:26 PM
Cummins engine swap? 98JPTJ TJ Wrangler Technical Forum 1 05-22-2003 02:19 AM
