cruising speed - JeepForum.com
post #1 of 13 Old 01-23-2013, 05:52 PM Thread Starter
Lrasser
cruising speed
i have a simply question. I've searched the threads and couldnt find anything. I have a 87 YJ 4.2 auto with 308 gears and 33's. What are you guys with simliar setups able to cruise at during highway speeds? I was thinking of regearing to 410's but im afraid with the 3 speed auto i might loose top end. As it is i feel like im pushing it getting to 65mph. Any input is appreciated.
Lrasser is offline
post #2 of 13 Old 01-23-2013, 06:00 PM
Mark05059
try this.. You can play around with tire size and gear ratios etc...
http://www.grimmjeeper.com/gears.html
note: your trans will probably be listed under dodge.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 13 Old 01-23-2013, 06:09 PM Thread Starter
Lrasser
thanks. tried it but didnt really help me much. couldn't make sense of the results
Lrasser is offline
post #4 of 13 Old 01-23-2013, 06:37 PM
SeanB95YJ
When you went to 33s, did you change your speedometer gear to accommodate the change?
What you THINK is 65 might actually be more like 75-80
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #5 of 13 Old 01-23-2013, 06:41 PM Thread Starter
Lrasser
I didnt change my speedo gear but im using my gps for speed. speedo is off by about 6-7mph by the time you hit 50mph.
Lrasser is offline
post #6 of 13 Old 01-23-2013, 07:11 PM
Mark05059
to use that chart you put in what you have for a trans (dodge tf 999) 231 transfer case and your rear axle ratio.. push calculate and scroll down till you see road speed.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #7 of 13 Old 01-23-2013, 07:54 PM Thread Starter
Lrasser
and it tells me I will be going 203840rpm's at 65mph
Lrasser is offline
post #8 of 13 Old 01-23-2013, 08:25 PM
Mark05059
I get 72 at 3k
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #9 of 13 Old 01-23-2013, 08:28 PM Thread Starter
Lrasser
with an automatic? what size tires? thanks!
Lrasser is offline
post #10 of 13 Old 01-23-2013, 08:31 PM
mrmark
that link works perfect for me
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
post #11 of 13 Old 01-23-2013, 08:32 PM
Mark05059
I used a TF999 and 33 inch tires (used your profile info) and a 4.11 rear ratio. I can change any info you wish or you can try it again
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #12 of 13 Old 01-23-2013, 08:48 PM Thread Starter
Lrasser
i got it to work. not sure how acurate this is though. I'll compare it to my speed and rpms's tom. thanks
Lrasser is offline
post #13 of 13 Old 01-24-2013, 06:48 AM
mrmark
It is accurate if you have the proper info on your stuff
mrmark is offline
