-   -   cruising speed (http://www.jeepforum.com/forum/f12/cruising-speed-1468050/)
Lrasser 01-23-2013 04:52 PM
cruising speed
i have a simply question. I've searched the threads and couldnt find anything. I have a 87 YJ 4.2 auto with 308 gears and 33's. What are you guys with simliar setups able to cruise at during highway speeds? I was thinking of regearing to 410's but im afraid with the 3 speed auto i might loose top end. As it is i feel like im pushing it getting to 65mph. Any input is appreciated.
Mark05059 01-23-2013 05:00 PM
try this.. You can play around with tire size and gear ratios etc...
http://www.grimmjeeper.com/gears.html
note: your trans will probably be listed under dodge.
Lrasser 01-23-2013 05:09 PM
thanks. tried it but didnt really help me much. couldn't make sense of the results
SeanB95YJ 01-23-2013 05:37 PM
When you went to 33s, did you change your speedometer gear to accommodate the change?
What you THINK is 65 might actually be more like 75-80 ;)
Lrasser 01-23-2013 05:41 PM
I didnt change my speedo gear but im using my gps for speed. speedo is off by about 6-7mph by the time you hit 50mph.
Mark05059 01-23-2013 06:11 PM
to use that chart you put in what you have for a trans (dodge tf 999) 231 transfer case and your rear axle ratio.. push calculate and scroll down till you see road speed.
Lrasser 01-23-2013 06:54 PM
and it tells me I will be going 203840rpm's at 65mph
Mark05059 01-23-2013 07:25 PM
I get 72 at 3k
Lrasser 01-23-2013 07:28 PM
with an automatic? what size tires? thanks!
mrmark 01-23-2013 07:31 PM
that link works perfect for me
Mark05059 01-23-2013 07:32 PM
I used a TF999 and 33 inch tires (used your profile info) and a 4.11 rear ratio. I can change any info you wish or you can try it again :2thumbsup:
Lrasser 01-23-2013 07:48 PM
i got it to work. not sure how acurate this is though. I'll compare it to my speed and rpms's tom. thanks
mrmark 01-24-2013 05:48 AM
It is accurate if you have the proper info on your stuff
The time now is 01:15 PM.
