Cruise Control Install on '92 YJ, 4.0L, 5 speed - JeepForum.com
post #1 of 11 Old 09-12-2012, 10:38 PM Thread Starter
cyoos
Mfr: Rostra
Rostra P/N: 250-1223
Source: Summit Racing
Control Panel Mfr: Rostra
Control Panel P/N: 250-3592
(This is the open circuit switch with the “Engaged” LED)
Additional parts required: 5 post relay to wire in this particular Control Panel (I forget the part number, but mine is Duralast from Autozone)
Optional Parts: Universal (Clutch) Disengagement Switch
Mfr: Rostra
Rostra P/N: 250-4206
cyoos is online now
post #2 of 11 Old 09-12-2012, 10:41 PM Thread Starter
cyoos
1. SET THE DIP SWITCHES BEFORE MOUNTING.
Dip Switch settings:
1 & 2 Gain Sensitivity: #1 OFF
#2 ON
3 – 6 Pulses/Mile (Pulses/Kilometer) #3 ON
For the Jeep this is set at 8,000/m (5,000/k) #4 ON
#5 OFF
#6 OFF
7 – 9 Engine/Setup Timer #7 OFF
Set to 6 Cylinder/Low #8 ON
#9 OFF
10 VSS Source #10 ON
Using vehicles computer this is set to
“Square Wave Input”
11 Transmission (Manual) #11 OFF
12 Control Switch (Open Circuit) #12 OFF
cyoos is online now
post #3 of 11 Old 09-12-2012, 10:49 PM Thread Starter
cyoos
2. Cruise unit install: To keep the required distance from the coil and distributor; the only reasonable mounting location I could find in my YJ's engine bay was to attach it to the support rod using 5/16” cable clamps from Tractor Supply.
The linkage is included in a universal parts kit included with the cruise control unit. I used some of the leftover linkage parts to complete the installation of my hand throttle.
3. Control panel install: The control panel had to be in close proximity to the hand throttle for the times when it's necessary for me to use them. I made a shift “knob” using four mountain bike handle bar extenders or grips. This required four sets of them since they come in left/right sets, and I had to use the same angle on all sections for it to work correctly.
The control panel itself is mounted on a bar extender that I sawed off and flattened in a vise.
cyoos is online now
post #4 of 11 Old 09-12-2012, 10:56 PM Thread Starter
cyoos
4. The “TACH” wire splices into the negative side of the coil. On my '92 this is a Yellow wire with a Black Stripe. I spliced into it at the connector inboard, below, and slightly forward of the battery.
cyoos is online now
post #5 of 11 Old 09-12-2012, 10:58 PM Thread Starter
cyoos
5. I grounded both Black ground wires from the cruise unit to a common ground inboard of the battery on the firewall.
cyoos is online now
post #6 of 11 Old 09-12-2012, 11:00 PM Thread Starter
cyoos
6. The wire harness routes into the passenger compartment through the factory firewall grommet.
cyoos is online now
post #7 of 11 Old 09-12-2012, 11:02 PM Thread Starter
cyoos
7. The VSS wire terminates to the White wire with the Orange Stripe. I opted to terminate this in the instrument panel at the instrument cluster connector.
Instrument cluster spd-tach connector with wht-org wire for speed signal .JPG
cyoos is online now
post #8 of 11 Old 09-12-2012, 11:03 PM Thread Starter
cyoos
8. The Brake Positive wire terminates to the Pink wire in the brake light switch harness.
9. The Brake Negative wire terminates to the White wire in the brake light switch harness. (This will not work with LED brake lights since it's signal is seeking ground. If you have LED's, you'll have to install an incandescent bulb in the circuit to make it function properly.)
Brake switch harness above ac blower pink is hot side and white is cold side of switch.JPG
cyoos is online now
post #9 of 11 Old 09-12-2012, 11:04 PM Thread Starter
cyoos
10. The Gray back lighting wire for the LED's on the control panel, I connected to the second wire down from the pink wire on the dimmer. This wire varied in voltage using the dimmer switch when I checked it with the meter, but the LED's don't dim. No big deal, the rest of it works well.
cyoos is online now
post #10 of 11 Old 09-12-2012, 11:06 PM Thread Starter
cyoos
11. The control panel requires a 5 post relay. Two posts are connected to the same ignition activated power source. I spliced into the primary “CRUISE” power wire since it's already switched at the fuse block. The Orange wire from the cruise unit, and the Pink wire from the control panel also connect to the relay. Diagram in the installation manual is self-explanatory for them.
cyoos is online now
post #11 of 11 Old 09-12-2012, 11:08 PM Thread Starter
cyoos
12. The Blue and Black wires from the Control Panel are grounded at the drivers door strap post.
13. The fuse block already has a contact for “CRUISE”.
I think that's it. The unit works great. I didn't install the disengagement switch, but I might. Without it, when you disengage the clutch the engine will race up by about 1,000 rpm momentarily before the “TACH” feature shuts down the unit.
cyoos is online now
My Cruise Control doesnt hold its speed when going downhill?? badazzelanore JK Wrangler Technical Forum 34 09-19-2012 11:33 PM
Cruise control install? letsroll TJ Wrangler Technical Forum 17 11-24-2010 01:58 PM
Cruise control 02 TJ 4.0L 5 speed. Maverickxeo TJ Wrangler Technical Forum 1 10-02-2010 04:49 PM
Speed/Cruise Control 1997 TJ 4.0L wdw TJ Wrangler Technical Forum 7 08-15-2009 08:19 AM
OEM cruise control install Rigger007 TJ Wrangler Technical Forum 31 06-16-2008 10:29 AM
