Cruise Control? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Cruise Control?
1995-1998 Jeep Grand Cherokee Front & Rear Brake Pad &Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 10-11-2009, 12:37 PM   #1
premierwheelman
Cruise Control?
I was wondering if anybody has any reccomendations for aftermarket cruise control in a YJ, I have been looking around for a kit but havent been able to find one.
premierwheelman is offline   Reply With Quote Quick reply to this message
Unread 10-11-2009, 12:52 PM   #2
GomerPyle585
the hand throttle seems to be pretty popular here...it's basically a bicycle thumb shifter mounted on the side of the shifter (on a manual) that can be adjusted as desired........it doesn't disengage when you hit the brakes like a normal cruise control does, but it can be used at any speed. i've not heard anything bad about them....do a search and check it out
GomerPyle585 is offline   Reply With Quote Quick reply to this message
Unread 10-11-2009, 09:08 PM   #3
dodger889
Why go after market it 's already there just have to wire it up and controller for the throttle. Goto to a junk yard and pull the controller and then vacuum reservoir. Then do some wiring You might have to use button or switches on the dash to control the ECM.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline   Reply With Quote Quick reply to this message
