CRT HEI Gear ... - JeepForum.com
post #1 of 10 Old 05-17-2013, 08:51 PM Thread Starter
shoebone
CRT HEI Gear ...
....... So I just installed the CRT HEI and coupled with the MC2150 the motor runs excellently, I'm really happy, but, just wondered, should I of changed the gear on the new dizzy? It is a hardened gear and I read that some people change it for a soft gear, but a lot of people run with the hardened gear. If I have to change it where would I get the soft gear ? anybody got a part number? or ... has anybody covered loads of miles with the HEI as is ?
Thanks for your insight
shoebone is offline
post #2 of 10 Old 05-17-2013, 09:18 PM
Old4X
1990 CJ7
Did you test the gear for hardness? There is a thread on the CJ forum that tells how to test.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 10 Old 05-18-2013, 04:57 AM
roadyrob
1987 YJ Wrangler
the CRT distributor gear is the correct one. I have had mine for over 5 years with no problems, probably over 35,000 miles. when I had my motor rebuilt I asked the rebuilder if he noticed any wear and he said everything was fine.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #4 of 10 Old 05-18-2013, 06:33 AM
Tarpo
My CRT had the hardened gear, and it ate my cam shaft gear on my 4.2 after about 25000. When I did my engine swap I kept the CRT, I just swapped the dizzy gear for the softer one
88 yj. 95 4.0 4 Brl carb, Msd ignition, offenhouser intake, headers. Ford 8.8 rear end, sun fire seats. About to install a newer ax 15 to replace my tired ba10.
Tarpo is offline
post #5 of 10 Old 05-18-2013, 09:35 AM Thread Starter
shoebone
Tarpo,
Do you remember where you got the softer gear from?
The CRT gear is definatly harder, I tried drilling it and the drill bit just slid off. I had no trouble drilling the original gear.
shoebone is offline
post #6 of 10 Old 05-18-2013, 09:50 AM
Tarpo
Originally Posted by shoebone
Tarpo,
My father in law owns a machine shop, he used the lathe and did some work on the original gear to make it fit on the CRT. I figured that would be my safest bet considering it came from the factory with that exact metal.
Tarpo is offline
post #7 of 10 Old 05-18-2013, 11:40 AM
roadyrob
1987 YJ Wrangler
you guys got me wondering about mine, but I've got quite a few miles on it. probably 25k before the rebuild, a little more than 10k since. maybe I'll pull the distributor and take a look, I'll let you know what I find.
roadyrob is offline
post #8 of 10 Old 05-18-2013, 12:28 PM
roadyrob
1987 YJ Wrangler
just pulled my distributor, could only see about 1/3 of the cam gear but it looked good.
roadyrob is offline
post #9 of 10 Old 05-18-2013, 12:28 PM Thread Starter
shoebone
25K miles, 35K miles ..... that's about ten years for me! I'll probably just run with the hard gear and see what happens
shoebone is offline
post #10 of 10 Old 05-18-2013, 01:40 PM
Tarpo
When it is starting to wear, it will look sharp on the edges. It may never wear out on you, but it did sneak up on me. And left me stranded.
Tarpo is offline
