CRT HEI distributor - JeepForum.com
post #1 of 12 Old 04-12-2010, 10:06 AM Thread Starter
Reverb
CRT HEI distributor
My jeep cut out on me this morning (AGAIN) and I had to take it to a shop to fix. They are telling me its the coil in the distributor. As far as I know they are based on GM HEI modules. What can I tell them to get to replace it?
Reverb is offline
post #2 of 12 Old 04-12-2010, 11:46 AM
pushead
Go to CRT's webite and look it up. I dont remember the specs but NAPA had it.
Its not a jeep if it dont have 4wd.
pushead is offline
post #3 of 12 Old 04-12-2010, 11:47 AM
vector6
standard GM HEI coil from advance auto / auto zone...
vector6 is offline
post #4 of 12 Old 04-12-2010, 11:48 AM
jbolty
jbolty's Avatar
mid 80's chevy 250, 6 cyl is the original base design.
the coil mounts to the distributor cap
jbolty is offline
post #5 of 12 Old 04-12-2010, 12:55 PM Thread Starter
Reverb
Thanks for the replies all. turns out it was the module not the coil. Ended up costing me $210+tax!! highway robbers!!
Reverb is offline
post #6 of 12 Old 04-12-2010, 12:58 PM
timatoe
timatoe's Avatar
Just checked some part numbers on Summit and the 350 and 250 applications are the same, so you should be able to get pretty much any HEI coil. You could just pull an application from this link... Summit Racing SUM-850011 - Summit Racing® HEI Ignition Coils - Overview - SummitRacing.com
timatoe is offline
post #7 of 12 Old 04-12-2010, 01:03 PM
JohndKc
1987 YJ Wrangler
I replaced the module with one from Pertronix for about 60 bucks if i remember. I am not sure which one you need though, but i would check out Summit Racing like Timatoe mildly suggested.
33rd BCT
Alpha 2/122 FA
68W
JohndKc is offline
post #8 of 12 Old 04-12-2010, 01:43 PM
wendell
1987 YJ Wrangler
210.00 bucks!!!! Did you tell them you just needed a new module, not a new jeep!!!!
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #9 of 12 Old 04-12-2010, 02:14 PM
vector6
vector6 is offline
post #10 of 12 Old 04-12-2010, 02:25 PM
timatoe
timatoe's Avatar
Ohhh, didn't see this when I first posted. Yeah, I bought a module at Kragen for like $24 when I first built mine. Hell they've got an entire replacement distributor for like $120 you just got to swap your current tip and gear.
timatoe is offline
post #11 of 12 Old 04-13-2010, 12:02 PM Thread Starter
Reverb
I had my hands tied. I was broken down on the grand central pkwy - AAA don't cover it. Had to get towed to the next exit - I was late for work and dropped it at a garage - $89 tow - $120 diagnostic fee - $90 part - all of which I could have done myself if I was upstate and not in the city. I couldn't exactly leave the jeep in the right lane of the grand central and go get the part (which I didn't know what it was at the time).
Sucks big time.
Reverb is offline
post #12 of 12 Old 04-13-2010, 12:11 PM
timatoe
timatoe's Avatar
Well, glad you got it up and running. I've been stuck like that before too, had to pay $85 for 5 gallons of gas, and that's back when it was still about $1.10 a gallon.
timatoe is offline
Cant get distributor set up Hanner89 YJ Wrangler Technical Forum 12 02-04-2010 10:40 PM
Distributor? sjeep1213 TJ Wrangler Technical Forum 5 03-20-2008 05:56 PM
Distributor cap ? Edward777 TJ Wrangler Technical Forum 3 03-11-2008 07:28 AM
HEI Distributor 89_Sahara YJ Wrangler Technical Forum 5 10-18-2005 03:31 PM
Wet Distributor 89_Sahara YJ Wrangler Technical Forum 4 10-17-2005 12:15 PM
