Quantcast Crossover Steering Help? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Crossover Steering Help?
Old 08-19-2009, 10:00 PM   #1
_JEEP_
i Installed my rugged ridge cross over steering today and when i install the draglink that goes from the pitman to the tierod end i realize it backwards and is binding with the diff. And in the instrustions it clearly illustrates that the draglink is suppost to be in front of the tierod and not in back of it.
but now the thing is that the tierod end only installs from the bottom of the steerng nuckle on a yj and which gives me no choice but to have the draglink in the back of the tierod...
Am i missing somthing or do i have the wrong part??
i drew an image of how it looks on the jeep. The tierod end in the back on the other tierod end is binding on the diff..
Check out my ----->BUILD THREAD
_JEEP_ is offline   Reply With Quote
Old 08-19-2009, 10:06 PM   #2
_JEEP_
And in the image its supposed to be infront like this.
HD cross over steering
Old 08-19-2009, 10:07 PM   #3
_JEEP_
Also i have tried everything imaginable. Nothing fits in that hole other than what's in there now, The way it is...
Old 08-19-2009, 10:22 PM   #4
_JEEP_
Anybody help? I'm gonna return the part tommorow?
Old 08-19-2009, 10:57 PM   #5
Castr8r
I'd go ahead and try it; I can't see where this would be a problem. See if it will cycle fully in both directions without binding/interference, and if there is none, then you're good to go.
Castr8r is offline   Reply With Quote
Old 08-19-2009, 11:53 PM   #6
91YJRockCrawler
i say put it on top of the nuckle, it would be the right way and you get it up out of the rocks
91YJRockCrawler is offline   Reply With Quote
Old 08-20-2009, 06:03 AM   #7
_JEEP_
you cant put it ontop ive tried. The hole is machine on a slight angle and so is the tierod end so the tierod end only fits one way.
Old 08-20-2009, 08:54 AM   #8
muddy93
1987 FSJ Wagoneer
is it possible that it's supposed to be hooked up like the steering linkage on a TJ?
on the TJ's, the drag link goes from the pitman arm to the passanger side knuckle. and the tie rod attaches to the drag link and then runs to the driver side knuckle. basically if you swap it so that the one you have labled as the drag link becomes the tie rod, and the one you have labled as the tie rod becomes the drag link.
like this,
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline   Reply With Quote
Old 08-20-2009, 09:07 AM   #9
Joe Dillard
Free clues & suggestions
Joe Dillard's Avatar
Possibly.
Are you 100% certain that RR even makes one designed for a YJ?
While looking at the RR website - it doesn't list one for a YJ (only for TJ, XJ & ZJ) but that could simply be a website update issue.
http://www.ruggedridgesales.com/Crossover-Steering-Conversion-Kit-PRD233.aspx
Joe Dillard is offline   Reply With Quote
Old 11-02-2009, 10:01 AM   #10
Aero540t
1981 CJ7
I just got the same setup from Rugged Ridge and have heard a lot of good things about it, but haven't heard anyone complain about binding on the diff.
Well with the help of my friend we got the thing installed last night and found I can't cycle the steering completely because the tierod hits the diff when turning left and it binds on the steering stabilizer mount when all the way right.
We couldn't figure out how to move the bumpstops out so he welded a nut up to it so now it's fine. It doesn't bind and I still have plenty of steering. I couldn't get my steering wheel centered because the drag link was a little too long. That's a little annoying. But overall the setup is pretty nice.
Aero540t is offline   Reply With Quote
Old 11-02-2009, 11:24 AM   #11
YJames90
aka Jamesx2
YJames90's Avatar
You have to remove the DL from the TR and attatch it to the steering knuckle like this
This is the JB4x4 bracket
My 2.5 to 4.3 swap thread
http://www.jeepforum.com/forum/f12/4-3-swap-has-finally-begun-1237704/
If your going to talk about me talk to me
YJames90 is offline   Reply With Quote
Old 11-02-2009, 12:14 PM   #12
Mitchness
I was wondering why you posed a crossover steering question then posted pics of a conventional setup. I agree with Jamesx2
Mitchness is offline   Reply With Quote
Old 11-02-2009, 01:06 PM   #13
linemen339
Your RR crossover steering has to have the tie rod go in from the front on a YJ. I have the same setup. You will have to move your steering stablizier also. I moved mine up to the trac bar bolt. It took 3 days to find out what was wrong with the set up. Here is a link to Quadractec web page for the RR crossover steering. Read the PFD file and it shows it setup that way. Hope this helps
Rugged Ridge 18050.83 - Rugged Ridge Heavy Duty Tie Rod Kit for 87-95 Jeep® Wrangler YJ - Quadratec
linemen339 is offline   Reply With Quote
Old 11-02-2009, 02:43 PM   #14
YJames90
aka Jamesx2
YJames90's Avatar
Originally Posted by linemen339 View Post
rod go in from the front on a YJ. You will have to move your steering stablizier also.
I still have on the original steering stablizier
Old 11-02-2009, 02:46 PM   #15
YJames90
aka Jamesx2
YJames90's Avatar
So your not doing cross over???
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
