Crossmember - Front Gas Tank Support - JeepForum.com
post #1 of 2 Old 09-24-2011, 08:16 PM Thread Starter
brentd711
I'm having some frame repairs done on my Jeep and need to repair or replace the rotted crossmember that the front of the gas tank skid attaches to. I found a replacement on line for $169 plus freight but I'm hoping the welding shop I'm using can do something quicker and cheaper.
The existing 15-gal tank in my '90 will be replaced with a 20-gal poly tank and factory skid. I'm also planning on adding a 1" body lift. Am I correct in thinking that (1) the tank is held to the skid by straps so this crossmember really doesn't provide any direct tank support or keep the tank from moving around and (2) that the critical dimension of a new crossmember is keeping the body mounts in the same height and location?
I did half an hour of searches here and the only thing I found was one that was fabricated to look pretty close to factory. I'm looking for ideas using angle or channel iron, something quick and easy.
brentd711 is offline
post #2 of 2 Old 09-24-2011, 08:57 PM
jsawduste
2006 YJ Wrangler
Yes the straps go to the skid but the skid bolts to the crossmember. You also have a couple body mounts on the cross member to think about. It is a pretty simple piece so your welder ought to be able to fab something up..
jsawduste is offline
Crossmember in front of fuel tank 95Turtle YJ Wrangler Technical Forum 4 07-12-2010 08:44 PM
Crossmember that supports front of gas tank Cards89YJ YJ Wrangler Technical Forum 1 02-17-2010 05:26 AM
Front Crossmember Replacement Nuge TJ Wrangler Technical Forum 17 05-05-2009 09:38 PM
lift installed, front DS hitting front crossmember need advice. kittyhawk TJ Wrangler Technical Forum 5 09-01-2007 09:43 PM
Rusting gas tank support 4x4xFun TJ Wrangler Technical Forum 5 01-01-2006 08:07 AM
