Is crossing heater hoses a bad thing?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Is crossing heater hoses a bad thing??
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6
Unread 02-06-2012, 02:39 PM   #1
ohio79
I recently replaced my blower motor. Drained the coolant. Put heater hoses back on. I noticed the hoses were different sizes but they went back on without having to force them on. Now im noticing i have a leak on the top of the radiator and my radiator cap was bad. If I put the hoses on backwards would that hurt the radiator or does it even matter?
ohio79 is offline   Reply With Quote
Unread 02-06-2012, 02:47 PM   #2
1SASjeepster
1SASjeepster's Avatar
It doesn't matter as long as there are no leaks because of the switch. On most new heater cores, the inlet and outlet tubes have different diameters. Some are close, some aren't. As long as those hoses aren't leaking where they connect to the heater core, you are good to go. The heater core will work the same no matter how they are hooked up AND that "switch" can't cause your other cooling system problems. That was something else.
Take care,
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline   Reply With Quote
Unread 02-06-2012, 02:50 PM   #3
ohio79
Damn that was fast. Thanks for the quick reply. Looks like im getting a new radiator.
Unread 02-06-2012, 03:00 PM   #4
jbolty
ISO 9001 Compliant
jbolty's Avatar
Take care,
Just one thing to add to this. If there was a build up of crud in the heater core it would get back flushed by reversing the flow. If it was a lot of stuff in there it could cause a clog somewhere else.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
