Creaking Noise when turning - JeepForum.com
post #1 of 4 Old 06-21-2010, 08:26 PM Thread Starter
Tyrannosaur
What can possibly cause a creaking noise when turning - especially after running for about 10 minutes. The noise sounds or reminds me of an old wooden ship. At first I noted the noise a bit in the front, now more in the rear, always when turning. At first I thought the differentials might be low on oil but both are full. This has been going on for a while, it does not seem dangerous but it is something I would like to fix.
Tyrannosaur is offline
post #2 of 4 Old 06-21-2010, 08:41 PM
Wild Hare
well once you have greased all the zerks on your steering and suspension and it still exists i would guess its just your spring packs racking during a turn from sideload.
Wild Hare is offline
post #3 of 4 Old 06-21-2010, 09:49 PM
Djsthe1
Or a possible U-joint going bad...
Djsthe1 is offline
post #4 of 4 Old 06-22-2010, 09:02 AM
grnsanddemon
If you still have your track bars, make sure eveything on them is tight, and also check the brackets.
grnsanddemon is offline
Creaking Noise dogboy6464 YJ Wrangler Technical Forum 2 07-24-2008 10:35 AM
creaking noise when gas and turn. bpowa TJ Wrangler Technical Forum 2 04-06-2008 05:25 PM
Creaking sound while turning wheels.. jthompsn TJ Wrangler Technical Forum 1 08-30-2007 12:25 PM
Creaking coming from front end when in 4wd...mostly when turning. Ford4Now TJ Wrangler Technical Forum 7 05-17-2007 11:16 AM
Creaking noise when turning 40 Thieves YJ Wrangler Technical Forum 5 06-24-2003 06:19 AM
