Crash Course In Brain Surgery Replacing Capacitors On ECU - Page 15 - JeepForum.com
 5Likes
post #211 of 299 Old 09-08-2013, 07:33 AM
Que89YJ
The o2 gets asd relay power for the heaters in the sensor so it gets up to temp as quick as possible.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #212 of 299 Old 12-30-2013, 09:00 AM
technologyteach
1957 CJ5
Thanks for the post, It worked on my 95 2.5 5 speed. Saved me a TON
technologyteach is offline
post #213 of 299 Old 01-05-2014, 01:59 PM
johnwiththree
Starts but new issues
Today I followed the instructions to replace the capacitors and my jeep starts immediately every time. It was easy and I thank you for the savings of hundred of dollars. I do have a new issue which came with this fix. Now the check engine light comes on when I turn the key, the fuel pump kicks on and the engine starts right up. However the check engine light does not turn off. The fuel pump does not stay on if I turn he key but don't start the engine. Also now I don't have high beams. When I turn them on the dash indicator shows high beam but the lights kick out?
Has anyone had issues like this?
johnwiththree is offline
post #214 of 299 Old 01-05-2014, 03:38 PM
Que89YJ
The girl pump is operating normal. The light is on because you have another fault:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Fault codes:
No Start:
Que89YJ is offline
post #215 of 299 Old 01-05-2014, 03:51 PM
johnwiththree
I noticed that the volt meter on the dash which normally reads 12-14 is at 16? any idea what is causing that.
post #216 of 299 Old 01-05-2014, 04:17 PM
Que89YJ
That is bad news if it is right you should absolutely not start it until you have a meter. The alternator is full fielded and putting out enough voltage to cause the battery to boil and explode. This is no joke. You need to see if it is accurate by measuring the voltage at the battery with a meter. If it is correct then you need to see off the pin for the alternator control at the ecu is shorted to ground. Post back.
Fault codes:
No Start:
Que89YJ is offline
post #217 of 299 Old 01-05-2014, 08:03 PM
johnwiththree
I did start the jeep to see what kind of drop I would get with lights and blower. It ran for about 30 seconds and I then looked at the battery to make sure all the connections where tight. I could hear the battery starting to boil. Can you help me locate the pin at the ECU and what to look for. Something definitely unsafe here.
thanks
post #218 of 299 Old 01-12-2014, 03:00 AM
Rnagade1
I want to add my thanks to the countless others who have done the capacitor change on the ECM. This was an amazing fix and so simple it was scary. I kept second guessing myself because nothing ever goes that smooth when working on a jeep! Lol. Thank you for saving me hundreds of dollars!
Rnagade1 is offline
post #219 of 299 Old 01-31-2014, 07:41 PM
snowgoer540
Capacitors
Excellent write up. Had to do this to my jeep recently, and I found it really helpful.
I just wanted to drop in my $0.02 about the capacitors. From what I read on the internet the brand that Radio Shack sells isn't really known for producing capacitors with quality electrolyte. The brand sold by Radio Shack is Lelon. The other problem with the caps sold there is that they are rated at 85 degrees C., whereas the ones that were installed from the factory are 105 degree C caps.
So I went a little further, and researched good brands of capacitors. What I came up with is a brand called Rubycon, and you can regularly find them on Ebay (from American Sellers) by searching Rubycon 25V 220uf High Temp Capacitor.
Just wanted to chime in here, of course I am sure the ones from Radio Shack work, but if the goal is to not have to replace them again at some point, it might pay to have this info regarding replacement options.
snowgoer540 is offline
post #220 of 299 Old 03-14-2014, 06:27 PM
joesseabee
I thank the author for the great fix. I just ran this process on my son's 94 yj manual 4.0, starting is nearly instant now, smoother running and the extreme tach flutter is gone. 3 220uf caps removed and replaced. fyi, my local radio shacks didn't have enough, but there was a bag o' 20 caps for about 5 bucks that had 4 of them
MM2/SS USN; CM1/SS USNR
Stop and smell the Mud.
2003 RHD 4.0 TJ postal / 1997 4.0 YJ (son's)
joesseabee is offline
post #221 of 299 Old 03-15-2014, 02:00 AM
peejjosh
So, just did this. Bolted it in just for a test fire and boom, fired like a champ! Tomorrow it goes back together for real
peejjosh is offline
post #222 of 299 Old 03-17-2014, 08:46 PM
kingjames2306
My jeep starts fine, the CEL comes on and turns off, no codes are being thrown, I haven't listened for the fuel pump. Ran fine when I bought it last summer and now with this extremely cold weather we've been having in upstate NY it's having problems. When it starts and I let it warm up on cold mornings, the idle gets so low and choked out that it seems like its about to stall then vroom, kicks back up to normal, then happens again, etc etc. When I start driving it'll choke out and then vroom gets going again (i've noticed it's usually in low RPMS) or I clutch it and it stops. This happens for about the first 5 minutes of driving then it goes away. Am I catching this capacitor problem before it really becomes worse and won't start or is it something totally different?
kingjames2306 is offline
post #223 of 299 Old 03-20-2014, 11:18 PM
joesseabee
that sounds more like an Idle Air Control valve sticking. 10-20 minute replacement, inexpensive part.
post #224 of 299 Old 03-21-2014, 06:03 AM
kingjames2306
i took it out and cleaned it a few weeks ago, think I should just try replacing it?
post #225 of 299 Old 03-21-2014, 06:13 AM
Que89YJ
POst up to a new thread with your problem and we can try and help you through it. This thread is for the ecu issue and we should try and keep post related to the ecu. PM me when you start a new thread.
Que89YJ is offline
ECU problems AGAIN (crash course in brain surgery) AhmedTheCamel YJ Wrangler Technical Forum 13 08-01-2010 07:52 PM
Pics of Capacitors in ECU SEMO 95 YJ YJ Wrangler Technical Forum 2 09-13-2009 09:00 PM
Back surgery Axl Jack Wrangler General Discussion 19 05-15-2009 08:35 PM
dana 30 surgery champelite210 YJ Wrangler Technical Forum 1 02-02-2008 05:18 PM
YJ in surgery now.... BigMac869 YJ Wrangler Technical Forum 4 02-06-2007 01:21 PM
