Crash Course In Brain Surgery Replacing Capacitors On ECU - Page 13 - JeepForum.com
 5Likes
post #181 of 299 Old 12-28-2012, 04:48 AM
jay-h
Originally Posted by flcracker View Post
Could grounding out the PDC feed back into the ECM and mess it up?? ... I can jump the fuel pump relay and get it to work and it will start after doing that but die within a few seconds. Could I have fried a capacitor??
If something is damaged by grounding it's not likely a cap. More likely a transistor or IC.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #182 of 299 Old 12-28-2012, 06:40 AM
flcracker
Could the ignition switch have been damaged by this?? It seems like its basically a mechanical switch is it not??
flcracker is offline
post #183 of 299 Old 01-23-2013, 10:19 AM
TECUMSEH
I broke a lead taking the capacitor out...what should I do?
TECUMSEH is offline
post #184 of 299 Old 01-23-2013, 10:34 AM
Que89YJ
Solder the lead of the replacement cap to the lead that is broken if it is long enough. If it is short then you need to get a solder sucker. These video's should help
https://www.youtube.com/watch?v=Aw4lZGk90i4
https://www.youtube.com/watch?v=BrAJpz9Mdm4
https://www.youtube.com/watch?v=AFsO-Qz0MGE
Que89YJ is offline
post #185 of 299 Old 03-03-2013, 08:39 AM
stompjrkz400
I followed your walk through, i now get a cel on start up, but no spark, everything else works great, i have a spare computer but its for a 4.0, and doesnt run my 2.5 very well, but i atleast have spark with it, any idea?
stompjrkz400 is offline
post #186 of 299 Old 03-03-2013, 11:47 AM
Que89YJ
You have to match the engine to the ecu. Since the other ecu its giving you spark you are going to need to replace the ecu.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #187 of 299 Old 03-03-2013, 02:11 PM
stompjrkz400
I understand that, I was just wondering if anyone knew the specific circuit that allows ECU to output spark, I am a computer engineer, and I have gone through the capacitors and the transformer, the only thing else that I feel that I should replace is the MOSFETs, but that is a little too much work so I will just buy another
post #188 of 299 Old 03-03-2013, 03:55 PM
Que89YJ
Not going to be the fets. The drivers are individual. It its probably the micro and it just isn't with the effort.
Fault codes:
No Start:
Que89YJ is offline
post #189 of 299 Old 03-03-2013, 03:56 PM
stompjrkz400
Exactly, ill just get a refurb, thanks btw!
post #190 of 299 Old 03-22-2013, 06:49 PM
Firefyter-Emt
Well, it's a going trend... but here's to the OP!
I picked up a non-running, yet very solid 1995 Rio-Grande that was non-running. I knew it had no spark, but was disappointed when the CKS tested good and I noticed the fuel pump not running. A little net surfing found me here, and sure enough I just replaced the three cap's tonight and I have spark! It's cold and dark, so I will check the fuel system better tomorrow, but it looks promising! By the smell of the fuel, she's been sitting for a while, and I have a few more things to work with still, like the brake lines... but I have spark!
Seriously guys... this is an awesome post!
That on top of finding a very clean set of half doors with the right tan trim panels and mirrors for $250 (for the set) just made my day!
I thought I would add a few more photos to show what I found. Now granted, I don't know just how long the Jeep has been sitting so these may of suffered from age after they stopped working.... but these caps are shot!
I will seal them up after I check the fuel system, it sounded like it came on.. but just to make sure, I want to leave it open.
Firefyter-Emt is offline
post #191 of 299 Old 04-09-2013, 10:40 PM
rajillio
Holy tits I just did this and it fired right up! Thanks for the post. I would have bought a new ecu if it weren't for this thread
rajillio is offline
post #192 of 299 Old 05-03-2013, 03:55 PM
imohamed
Another Success Story
I was having the same issues, 94 YJ 4 Cyl would just turn and turn when it was cold outside. Took it to a couple of mechanics that couldn't figure it out. My wife had me pretty well convinced that it was time to let her go, and I almost let her defeat me. Stumbled onto this post back in November and decided to give it a run.
Never soldered anything in my life - burnt the crap out of my finger, those things get hot. Popped the ECM back in and she started right up. Just to make sure I didn't jinx anything I decided to see how she handled through the winter before posting the success.
Seriously, this thread saved me Jeep, I cannot thank the OP enough for posting this information. My wife, who was not very supportive through this and laughed her *** off after I burned myself, hates your guts.
Here are a couple of pics
http://i702.photobucket.com/albums/w...1121-00037.jpg
http://i702.photobucket.com/albums/w...1121-00036.jpg
imohamed is offline
post #193 of 299 Old 06-20-2013, 08:07 PM
Maineshootah
i have been on the fence about being a supporting member of this forum... however this thread sealed the deal for me to pony up!
My 95 always started on the second key turn since I bought it a few years ago.
This winter she sat for several months after the frame swap.
This week, I was starting to see the signs that "brain surgery" was in order, turn the key, no CEL for 45 -90 seconds...
FRANTIC, I started searching the forums and came upon this thread.
I ran out to the local Radio Shack(s) (as I had to hit two of the to get all of the caps) picked up the pair of 220uf and one of the 470uf, about 6 bucks. Then I splurged on desolder braid, 5 bucks and a Rat Shack 35w soldering pen with stand and solder..etc.. you know, the "kit" they sell. Another $13. tube of silicone 5 bucks. All in about $30. Followed the directions here in the thread.
Disconnected the battery, moved the windshield washer fluid container, took out the computer, removed the board, cut away the balastics gel, removed the caps, put in the new ones, filled in the gell holes with silicone, reversed the order to put it all back.
Jumped in the seat, took a deep breath and turned the key. CEL and the other lights came right on, and the engine started on the first crank.
YEAH BABY !!
How excited is this guy!
THANK YOU!
I guess my YJ Is my midlife crisis therapy.....
My 95 YJ cross country (AZ to ME) frame swap thread.
http://www.jeepforum.com/forum/f22/maineshootahs-cross-country-95-yj-build-1487587/
Maineshootah is offline
post #194 of 299 Old 07-15-2013, 09:23 PM
yjgirl88
Thank you so much for the post. Got my YJ about a month ago and have had the problem for about three weeks. Had everyone stumped and like most other have posted, the initial thought was the fuel pump. I Have a 4.0 and had to use 3 220uf capacitors.
I was so nervous about doing it, but glad I did.
Thanks again, I can't thank you enough!
yjgirl88 is offline
post #195 of 299 Old 07-16-2013, 01:13 PM
MIDLIFJP
Hi . I purchased a 1995 wrangler recently. It would crank but not start. It would finally start after a minute or so. I found this thread and figured I didn't have much to loose so I made a trip to Radio Shack and picked up 3 220uf capacitors.
Removed ecu replaced capacitors as noted in this thread and reinstalled ecu. VROOOOM! Started right up.
Total time: 1 hour (not including trip to Radio Shack)
Total cost: $1.49 x3 plus tax for a grand total of $4.86
THANK YOU! THANK YOU! THANK YOU!
MIDLIFJP is offline
ECU problems AGAIN (crash course in brain surgery) AhmedTheCamel YJ Wrangler Technical Forum 13 08-01-2010 07:52 PM
Pics of Capacitors in ECU SEMO 95 YJ YJ Wrangler Technical Forum 2 09-13-2009 09:00 PM
Back surgery Axl Jack Wrangler General Discussion 19 05-15-2009 08:35 PM
dana 30 surgery champelite210 YJ Wrangler Technical Forum 1 02-02-2008 05:18 PM
YJ in surgery now.... BigMac869 YJ Wrangler Technical Forum 4 02-06-2007 01:21 PM
