Crash Course In Brain Surgery Replacing Capacitors On ECU - Page 11 - JeepForum.com
 1Likes
post #151 of 296 Old 12-29-2011, 12:09 AM
patbe
After obtaining three 220 uf 35v capacitors and returning home and removing ecu and preparing for capacitor replacement I see that one of the capacitors is a taller 470 uf 25v. Has anyone run into this? Is it ok to use the 220 uf 35 volt or do I need to get a 470uf? Please and thanks.
patbe is offline
post #152 of 296 Old 12-30-2011, 12:26 AM
Domgia
Hey,
I ran into the same thing while doing mine, I went to radio and picked up the 470
In my opinion I think it would be a bad idea to replace it with a 220
Goodluck
- Dom
Domgia is offline
post #153 of 296 Old 12-30-2011, 04:29 PM
patbe
Originally Posted by Domgia View Post
Hey,
Goodluck
- Dom
Ya, heres what I did. I tried replacing just the two 220uf capacitors, plugged it in to jeep...no go. So then I drove the 60 miles to town and picked up a 470uf and soldered it in. Hooked it up and...................success, fuel pump cycled and it fired right up. An awesome fix. Thanks to the original poster of this fix and contributers.
patbe is offline
post #154 of 296 Old 12-31-2011, 03:05 PM
Que89YJ
Thew voltage was a bigger issue then the capacitance. Glad to hear it worked.
Que89YJ is offline
post #155 of 296 Old 01-04-2012, 09:27 PM
rsegriggy
1981 CJ7
Hey,
Goodluck
- Dom
Do you have a 4.0 YJ? I found I have the 470 as well. Just curious as to why some have all 220 and some have a 470.
rsegriggy is offline
post #156 of 296 Old 01-05-2012, 06:15 AM
Que89YJ
470uF is a filter cap freq response that moved the effective reactance of the cap to the 1Mhz or the AM band. It's just a minimal change for the frequecy cutoff of the cap. The voltage is more important in the application it's being used.
Que89YJ is offline
post #157 of 296 Old 01-06-2012, 10:58 AM
megagab
Thank you very much for this guide!
I had the same problem, I followed your instructions and now my YJ 94 starts like a champ even at -25 C
megagab is offline
post #158 of 296 Old 03-25-2012, 07:54 PM
woodinrock
This thread is very helpful. I have all the symptoms, followed sentinal02's link, everything is pointing at the ecu. Gonna give this a try as soon as I can make it to Radio Shack. I'll let you know how it goes, I'm doing this on a 93 zj.
woodinrock is offline
post #159 of 296 Old 04-22-2012, 01:41 PM
tomemt
Just out of curiousity would this fix my problem no fuel pressure and replaced pump, filter and pressure regulator with no fuel pressure and only like 5 volts at the harness fuses and relay are good. No spark but have power to everything an it's all been replaced except ignition itself?!???
tomemt is offline
post #160 of 296 Old 04-22-2012, 09:37 PM
Que89YJ
Does your check engine light come on when you turn the key? If the light does not come on and go off when you cycle the key on then you have the ecu issue. If it does then your problem is something else.
Que89YJ is offline
post #161 of 296 Old 04-23-2012, 03:16 PM
tomemt
Just a note my '92 4.0 5spd had 2 220uf and 1 470uf so if your gonna do this buy a 470uf just in case and 3 220uf...it beats getting it all apart an having to go back to buy it cause yours has a 470uf
tomemt is offline
post #162 of 296 Old 04-26-2012, 06:25 PM
skoz
Capacitor!
I own a 93 grand Cherokee and have the problems with the chatter in the fuel pump/auto shut down relays. And after reading this original post i checked my PCM capacitors and clearly saw a bad cap. But the cap I have is a brown 220,uf 25v and after calling radio shack they only carry the 35v is this really ok to go up in size?
skoz is offline
post #163 of 296 Old 04-26-2012, 07:39 PM
Que89YJ
in the right up it says that he used to 35dc cap.
Que89YJ is offline
post #164 of 296 Old 06-10-2012, 09:53 PM
pooljunky
Hey Guys, about this , Is it the exact same thing for a 2.5L 2001 wrangler?
pooljunky is offline
post #165 of 296 Old 06-10-2012, 10:32 PM
Que89YJ
No. it is a totally different controller.
Que89YJ is offline
ECU problems AGAIN (crash course in brain surgery) AhmedTheCamel YJ Wrangler Technical Forum 13 08-01-2010 08:52 PM
Pics of Capacitors in ECU SEMO 95 YJ YJ Wrangler Technical Forum 2 09-13-2009 10:00 PM
Back surgery Axl Jack Wrangler General Discussion 19 05-15-2009 09:35 PM
dana 30 surgery champelite210 YJ Wrangler Technical Forum 1 02-02-2008 06:18 PM
YJ in surgery now.... BigMac869 YJ Wrangler Technical Forum 4 02-06-2007 02:21 PM
