Crankshaft Sensor Help - JeepForum.com
post #1 of 5 Old 01-20-2014, 07:12 AM Thread Starter
Callan74
OK..long story short. Replaced the clutch on my 1989 2.5L YJ, every parts store I called said that the 1989 4 banger flywheel was not available, so I progressively moved up in years until I found a 1991 flywheel. Everything on the two flywheels matched perfect..except the outer flywheel notches. I assumed the outer notches were for balancing and weight (not even thinking about crankshaft sensor). I finally finished the new clutch install and had everything put back together. I tried to start the jeep and it will turn over but no spark. After troubleshooting a few things including the crankshaft sensor (ohms) still nothing, so I am assuming the 1991 flywheel will not work with the 1989 electronic setup.
So the dilemma and question. Does anyone know if a 1991 crankshaft sensor will work on an 1989? The plugs are different and not sure the mode of operation is even the same. Is coil/ignition module and computer even compatible? These are just desperation questions...I really do not want to tear apart the jeep to switch out the flywheel (if I can even find one). Does anyone have other ideas?
C
Callan74 is offline
post #2 of 5 Old 01-20-2014, 08:21 AM
Mark05059
you have 2 different animals.. TBI and MPFI. The cps is not the answer..the flywheel needs to be correct.. or change to a MPFI setup and it should start but that involves a new ECM as well
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 5 Old 01-20-2014, 09:20 AM
Peety
Originally Posted by mark05059 View Post
you have 2 different animals.. Tbi and mpfi. The cps is not the answer..the flywheel needs to be correct.. Or change to a mpfi setup and it should start but that involves a new ecm as well
x2
Peety is offline
post #4 of 5 Old 01-20-2014, 09:55 AM
Que89YJ
X3 if you need a source for a good used one try cfoffroad.com
Chris will probably have one
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #5 of 5 Old 01-20-2014, 05:59 PM Thread Starter
Callan74
Thanks, thats what I figured...I found a local machine shop to turn the old flywheel. Strange that I cannot find a new one at the local parts stores..I tried 3 different ones.
Callan74 is offline
