Crankshaft Position Sensor - Where is it?.... - JeepForum.com
post #1 of 5 Old 01-01-2009, 12:52 PM Thread Starter
hardijr
I know it is attached to the transmission housing, but which side, driver's or passenger's side? This is a 4.0L engine. Thanks in advance.
hardijr is offline
post #2 of 5 Old 01-01-2009, 12:57 PM
themonkeyman
1987 YJ Wrangler
Should be on the drivers side. Imagine you are looking at the bellhousing, and looking towards the rear of the jeep.(imagine the engine is removed) It should be at about 1 O'clock.
themonkeyman is offline
post #3 of 5 Old 01-01-2009, 01:01 PM Thread Starter
hardijr
Found it.....thanks man.
hardijr is offline
post #4 of 5 Old 04-16-2010, 10:40 PM
SierraNev
Hey ya'll I am having intermittent issues with my Jeep stalling while driving after a few minutes or at idle speed and after warm up. The codes for pcm not getting signal from cps/cpk "crankshaft positioning sensor" came up. So now that I've gotten that far how the heck do you get to the bugger, take the tire and inner tire panel off or drop the trany? I got a chilten with microscopic pic's and a fellow said I would need a pully puller, I think I can handle it with a lil direction. How bout it fellow Jeepers, a brotha could use some help, its our only car right now. 99 Jeep Grand Cherokee Limited 4.7L
SierraNev is offline
post #5 of 5 Old 04-16-2010, 10:55 PM
whitie_08
try the wj tech section
^^^thats a lie.
whitie_08 is offline
Crankshaft Position Sensor or Camshaft Position Sensor? TennesseeTJ TJ Wrangler Technical Forum 20 07-31-2017 12:22 PM
Crankshaft position sensor lightwalk333 YJ Wrangler Technical Forum 12 02-18-2009 11:43 AM
Crankshaft Position Sensor JeeperAbe TJ Wrangler Technical Forum 4 05-10-2008 02:26 PM
Crankshaft Position Sensor jeep'd YJ Wrangler Technical Forum 6 03-15-2007 12:00 PM
Crankshaft Position Sensor...again?? cmorganf64 TJ Wrangler Technical Forum 9 05-04-2006 12:45 PM
