Crankshaft Position Sensor, Which One? - JeepForum.com
post #1 of 10 Old 03-04-2013, 05:23 PM Thread Starter
az_zoner
I'm getting a code 11 and it could be my CPS. My questions is which one should I get? My yj is a 91. Everything is 91 except for a new engine which is a 94 with a 94 distributor and coil (if that matters). So when I look it up the part numbers they are broken down with a 91 and 82 has one and the 93 thru 95 has a different one.
Any idea?
Craig
az_zoner is offline
post #2 of 10 Old 03-04-2013, 05:39 PM Thread Starter
az_zoner
Just checked the sensor and it is at 69 ohms. So pretty sure it's bad. Need to figure out which one to get.
cb
az_zoner is offline
post #3 of 10 Old 03-04-2013, 05:42 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
cb
Which year ECM controls the emissions system on your Jeep? '91? Then that year sensor would be the logical choice.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 10 Old 03-04-2013, 05:56 PM Thread Starter
az_zoner
Thanks, It is a 91. I was leaning that way. I checked and the distributor sensor is the same for those years.
And I just got a good look at both and it is the mounting strap that is difference between the two.
cb
az_zoner is offline
post #5 of 10 Old 03-04-2013, 06:08 PM
Siva283
91 and 94 use the same crank sensor.
Sent from my Galaxy S3 using JeepForum
Ask me how I know...
Siva283 is offline
post #6 of 10 Old 03-04-2013, 07:00 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
cb
Here is the one I think you need.
http://www.rockauto.com/catalog/more...349&cc=1185005
post #7 of 10 Old 03-04-2013, 07:12 PM
ghetdjc320
94 PCMs are a little different IIRC. I believe the 94 dizzy will have a different Camshaft sensor signal.
-DJC
ghetdjc320 is offline
post #8 of 10 Old 03-04-2013, 07:19 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Between 91-94 several different crank sensor part number show up.
post #9 of 10 Old 03-05-2013, 05:48 PM Thread Starter
az_zoner
Picked up a sensor at NAPA for a 91 YJ and it runs great again. I think it was going down hill for a while because it actually feels a little smoother.
thanks for all the input!!
Craig
az_zoner is offline
post #10 of 10 Old 03-06-2013, 05:40 AM
Que89YJ
The PCM and the signal is the same. The sensor connector changed. You can cross over the 2 with no difference in the way it will operate. The older one is round while the newer one is flat.
Que89YJ is offline
