cranks n cranks but will not start??? - JeepForum.com
post #1 of 9 Old 01-13-2012, 03:53 PM Thread Starter
xpoetax
so my '92 yj will not start when its cold out. When its above 40 degrees it cranks for about 10 seconds before it starts and it has to be full throttle. When temperature drops it cranks and sort of "catching" but the battery will die before it starts.
I got sprark, got fuel - i can hear the fuel pump n after cranking it so long i can smell it. I also have see the CEL light up.
If i jump it and crank it for a while it will start and once it warms up it starts everytime but still needs like 5-10 seconds of cranking.'
ANY IDEAS?? Please help
xpoetax is offline
post #2 of 9 Old 01-13-2012, 03:58 PM
nembudonna
Try a new battery.
nembudonna is offline
post #3 of 9 Old 01-13-2012, 04:17 PM
dmblair
Hey man, take a read through this thread (http://www.jeepforum.com/forum/f12/9...).....it's one I started a year ago. My issue is still here somewhat but it's better. A lot of guys who know a crapload have commented and put many helpful suggestions throughout this thread. Good luck!! Keep us posted
dmblair is offline
post #4 of 9 Old 01-14-2012, 11:19 AM Thread Starter
xpoetax
Read the entire discussion mentioned above and I am still clueless! I got fuel I got spark n I have to jump it n crank it for honestly 5min before it starts. And it has to be WOT!
xpoetax is offline
post #5 of 9 Old 01-14-2012, 11:27 AM
youngjeepr
try spraying starter fluid in the throttle body see if that makes it start if it does then its a fuel problem
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #6 of 9 Old 01-14-2012, 02:54 PM
dmblair
Have you checked your fuel pressure? I'm curious to see what that is?!!?
dmblair is offline
post #7 of 9 Old 01-25-2012, 11:11 PM Thread Starter
xpoetax
I did the ecu capacitor replacement. Cap rotor wires. N still need to start it wot. No codes in the ecu. Once it starts n warms up it bogs down between 1500-2000 in 1st gear.....
xpoetax is offline
post #8 of 9 Old 01-25-2012, 11:11 PM Thread Starter
xpoetax
Starting fluid doesnt help!!!
xpoetax is offline
post #9 of 9 Old 01-26-2012, 07:09 AM
Que89YJ
If you are having a sart issue then it limits it to a few sensors. Clean the throttle body and the IAC. It sounds like a bad IAC. TPS is possible and can be easily checked with a meter and the Temp and MAT. Since you are going WOT to start I am betting your issue is the IAC though. There is a good writeup on cleaning it. Do the search. The IAC seems to be a huge problem with the years on the Jeeps now.
Que89YJ is offline
cel , cold , computer , crank , start
Cranks and Cranks, cranks some more and she wont start. crzylgzz YJ Wrangler Technical Forum 37 12-09-2011 03:44 PM
Jeep cranks and cranks, will not fire VegasMatt TJ Wrangler Technical Forum 36 09-08-2010 11:37 AM
My Jeep Cranks And Cranks But No Start!!! b1ack2tar YJ Wrangler Technical Forum 5 01-14-2009 08:23 AM
cranks, but doesn't start. MugZy_YJ_94 YJ Wrangler Technical Forum 2 11-25-2007 01:42 AM
Cranks but does not start. 95 YJ drew4040 YJ Wrangler Technical Forum 0 11-18-2007 08:57 AM
