Cranks but wont start!! Need help - JeepForum.com
post #1 of 16 Old 04-11-2013, 09:41 AM Thread Starter
Snakebite22
So I gotta 95 yj 2.5 an can't get her to start has new fuel pump and filter, cps, starter and battery will all new fresh fuses an still wont start tested my fuel pressure an everything good on that part but would the ignition switch have any play
Snakebite22 is offline
post #2 of 16 Old 04-11-2013, 10:45 AM
Que89YJ
Start by checking your fault codes and posting what you find:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Que89YJ is online now
post #3 of 16 Old 04-11-2013, 11:00 AM Thread Starter
Snakebite22
There's no codes
post #4 of 16 Old 04-11-2013, 11:00 AM
Que89YJ
No codes at all? The CEL doesn't flash?
post #5 of 16 Old 04-11-2013, 11:15 AM Thread Starter
Snakebite22
The only one is for the ac that I don't have lol
post #6 of 16 Old 04-11-2013, 11:39 AM
Fellows45
Alright, i had the same thing happen to me... I went and redid all the wiring in my jeep... take a can of electrical cleaner and clean out all of the connections and make sure everything is properly hooked up...this solved my no start problems and she runs better than ever before now!
Fellows45 is offline
post #7 of 16 Old 04-11-2013, 11:49 AM
Que89YJ
It is not the ignition switch if it turns over and you can see the fault codes. You say you have fuel pressure, did you check to see if you have spark?
post #8 of 16 Old 04-11-2013, 11:55 AM Thread Starter
Snakebite22
I got new plugs but to check I just take out #1 an put it against the block to to if it sparks up right
post #9 of 16 Old 04-11-2013, 11:59 AM Thread Starter
Snakebite22
Ya an I have fuel pressure
post #10 of 16 Old 04-11-2013, 12:25 PM Thread Starter
Snakebite22
I had a buddy say it could be the distributor it is pretty damn old
post #11 of 16 Old 04-11-2013, 12:29 PM
Que89YJ
Is the spark blue? Nice solid arc? If yes then:
There are 2 possibilities. The fuel pressure is incorrect, or the spark is not reaching the plug in time. You need to get some starter fluid and remove the air tube, open the throttle plate and shoot starter fluid strait into the throttlebody and see if it fires over. Post back if it does crank over. If it does then you will need to grab a fuel pressure guage at the parts store tool loan program.(Fully refindable deposit).
If it doesn't then the problem is probably the pickup sensor in the distributor not firing the plug at the right time. The pickup sensor is sold seperately or as a unit with the entire distributor. I recommend the entire distributor.
post #12 of 16 Old 04-11-2013, 02:03 PM
Diez
I had a problem similar to this last night. Ended up being a terrible ground from the battery. Fuel was being slowed down from the pump due to it. Ran a quick ground wire to the body and started right up.
Diez is offline
post #13 of 16 Old 04-11-2013, 02:21 PM
Siva283
I agree with Que if its the pick up in the distributor replace the whole thing as a unit. Its only an extra $20 and then you wont have to worry about it wearing out for a long time.
Ask me how I know...
Siva283 is offline
post #14 of 16 Old 04-11-2013, 06:21 PM Thread Starter
Snakebite22
Got a new dist an started up thanks guys for the help
post #15 of 16 Old 04-11-2013, 06:25 PM Thread Starter
Snakebite22
Got a new distributor an she started up thanks guys going to let her run for a bit an take it around the block will let you know if anything else happens
