Cranks but wont start - JeepForum.com
post #1 of 15 Old 02-13-2013, 07:54 PM Thread Starter
robx316
Problem Solved
Now i cant get th jeep tostart its. 92 4.0
It cranks and wants to start then stops. I also noticed the rpms arent moving.
Would that keepit fromstarting?
Where is thr sensor for thst?
My build thread
http://www.jeepforum.com/forum/f12/prolonged-yj-build-1470550
robx316 is offline
post #2 of 15 Old 02-13-2013, 08:52 PM
Mark05059
turn the key to the on position... dont try and start it.. keep watch for the check engine light (should come on right away and then go out in about 3 seconds) if it does then the computer is good... if it doesnt come on right away.. wait (could be up to 2 minutes) with the key on for the light to come on... you will hear a few clicks etc when the light comes on... then turn it to start..
report back on your findings
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 15 Old 02-13-2013, 10:00 PM Thread Starter
robx316
Yes it comes on right away. And i got the rpms to show. But now its running rough and rpms drop to stall. Now im thinking TBS?
My build thread
robx316 is offline
post #4 of 15 Old 02-14-2013, 06:09 AM
Que89YJ
Start with the basics. Check your codes and post back what you find:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
No rpm is a cam(Distributor pickup) or the more likely issue(Since rpm indication comes from the CPS) The crank position sensor.
Que89YJ is offline
post #5 of 15 Old 02-14-2013, 06:32 AM Thread Starter
robx316
thanks i've counted 3 times and every time i've gotten 35 and 76 which arent listed?
I will check readings on Cps
My build thread
robx316 is offline
post #6 of 15 Old 02-14-2013, 07:01 AM
Berniebikes
Here ya go. Would first investigate the possible fault for your fuel pump
Code 76-Ballast bypass relay-open or short in fuel pump relay circuit.
Code 35-Radiator fan control relay circuit-open or short detected in teh radiator fan relay circuit.
Berniebikes is offline
post #7 of 15 Old 02-14-2013, 08:01 AM
Que89YJ
Did you get 12,33, and 55 as well?
Que89YJ is offline
post #8 of 15 Old 02-14-2013, 09:31 AM Thread Starter
robx316
its an islander so It had A/c
start 12
35
76
end 55
My build thread
robx316 is offline
post #9 of 15 Old 02-14-2013, 10:02 AM
Que89YJ
No the ac is a different thing. Dont worry about it though. code 76
Que89YJ is offline
post #10 of 15 Old 02-14-2013, 10:05 AM
Que89YJ
Sorry. The codes you are throwing can only be there because the ecu was swapped out at some point. No big deal. It is from an XJ. Back to the issue it sounds like the crank position sensor if you don't see rpm.
Que89YJ is offline
post #11 of 15 Old 02-14-2013, 10:08 AM Thread Starter
robx316
yea, that's looking like the culprit I got no continuity.
I'll report back this afternoon when it comes in.
My build thread
robx316 is offline
post #12 of 15 Old 02-14-2013, 05:14 PM Thread Starter
robx316
Replaced the cps and got it to run shortly. Ran really rough and the. Stalled out
My build thread
robx316 is offline
post #13 of 15 Old 02-14-2013, 06:59 PM
Que89YJ
Did the rpms on the gauge drop out before the stall? I think you are describing a fuel issue but I have a couple things to try. Disconnect the battery for a 10 count. Try and start and run. Next disconnect the temp sensor at the tstat and the O2 sensor. Run it and if it doesn't make a difference shut it down and disconnect the battery. Last and what I really think is bad you need to go rent the pressure gauge from the borrow program at the parts store and see what your fuel rail pressure is. You should see 31 psi. Let it idle until your problem happens.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #14 of 15 Old 02-14-2013, 09:29 PM Thread Starter
robx316
yea that's what I was figuring after all that
I dropped the tank and am putting in clean fuel and grounding the pump to frame.
will keep you posted..
My build thread
robx316 is offline
post #15 of 15 Old 02-17-2013, 07:05 AM Thread Starter
robx316
Thanks for all the help
turns out the connector on the fuel sending unit was pulling apart.
also the gas looked like snot and I flushed it out and got some fresh gas in there
purring like a kitten now!
My build thread
robx316 is offline
