crank sensor.. HELP - JeepForum.com
post #1 of 9 Old 06-21-2010, 04:14 PM Thread Starter
nickaldrich
crank sensor.. HELP
i have a 94 wrangler and i put in a 4.0l out of a 92 cherokee and the wiring harness was from a 92 wrangler 4.0l... well everything was plug and play but the crank sensor plug.. was just going to switch the ends but the wiring is differnt colors.. can someone please help me with both wiring codes or should i just buy a 92 wrangler crank sensor?? Thanks with any help
nickaldrich is offline
post #2 of 9 Old 06-22-2010, 08:11 AM Thread Starter
nickaldrich
Nobody??
post #3 of 9 Old 06-22-2010, 08:21 AM
Que89YJ
gy/bk - PCM
org - Power
bk/lb - ground
Que89YJ is online now
post #4 of 9 Old 06-22-2010, 10:12 AM Thread Starter
nickaldrich
I have a
white/black
blue/red
brown/red
post #5 of 9 Old 06-22-2010, 10:38 AM
Que89YJ
This is what your looking for.
Flickr Photo Download: 92 cps
post #6 of 9 Old 06-22-2010, 10:56 AM Thread Starter
nickaldrich
Thanks again.. do you know the color codes for the 94 so i can wire them together??
post #7 of 9 Old 06-22-2010, 11:13 AM
Que89YJ
post #8 of 9 Old 06-22-2010, 11:18 AM Thread Starter
nickaldrich
Your awesome buddy.... thanks
post #9 of 9 Old 06-22-2010, 11:25 AM
Que89YJ
Your welcome.
5.2 crank sensor GUS672 TJ Wrangler Technical Forum 2 07-19-2012 11:44 AM
Crank Pos Sensor? 04TJSport TJ Wrangler Technical Forum 13 07-07-2009 04:24 PM
My 2.5 takes a while to start, is it the cam sensor or crank sensor!! Divebum TJ Wrangler Technical Forum 9 12-24-2008 01:38 PM
Crank sensor didn't do it swami2806 YJ Wrangler Technical Forum 0 11-04-2007 02:21 PM
TPS and Crank Sensor aju4 TJ Wrangler Technical Forum 0 07-14-2005 08:59 AM
