Cracked manifold? - JeepForum.com
post #1 of 14 Old 02-27-2013, 06:58 PM Thread Starter
kjg26
kjg26's Avatar
Cracked manifold?
I purchased a new exhaust manifold for my 93 from 1 A Auto. After pulling the Thunder it appears the manifold that is on there is 1 of the newer styles with the flex joint. I'm thinking my exhaust manifold may not be cracked or leaking it may just be a loud exhaust system. Is there a way to test if the exhaust manifold is cracked or not
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 14 Old 02-27-2013, 07:04 PM
demonz0
I would test by starting your Jeep after its been sitting/cold and run your hand all around exhaust feeling for the warm air puffs coming out. How I found both of my cracked manifolds.
99 Cherokee 4.0L | 4.5in Lift | 33x12.5
94 YJ 4.0L | 4in RC Lift | 33x12.5
demonz0 is offline
post #3 of 14 Old 02-28-2013, 04:53 AM
nembudonna
I had to replace my head gasket and ever since then it's a little louder. I think mine's comming from where the exhaust pipe meets the manifold. There's no donut there.
nembudonna is offline
post #4 of 14 Old 02-28-2013, 05:28 AM
willawolfe
I don't know exactly how to but you may look into using smoke. May just be a technique used to find vacuum leaks, maybe someone else could shed light.
willawolfe is offline
post #5 of 14 Old 02-28-2013, 05:35 AM
EABiker
Do a Seafoam treatment; you can clean up the carbon deposits and generate smoke for the leak test. Have someone cover the tailpipe with their shoe with the engine running; it will force more exhaust gas out of the leak.
EABiker is offline
post #6 of 14 Old 02-28-2013, 05:44 AM
Que89YJ
You need to disconnect rad fan. The pipe method its good at isolating any noise. Are you blowing an O2 fault?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #7 of 14 Old 02-28-2013, 05:56 AM Thread Starter
kjg26
kjg26's Avatar
No fault codes. Just noisy. Disconnecting the rad fan will be easy with the taurus fan!!! So stop the fan. Shoe over the pipe and run seafoam through the vac system. Check for smoke...?
kjg26 is offline
post #8 of 14 Old 02-28-2013, 07:06 AM
Que89YJ
You can do it with a cigarette or an insense stick. Just look for the smoke being push by a leak. If you had a diagnostic ttol that could read the O2 sensor voltage you would monitor the O2 sensor and spray with carb cleaner and look for the voltage spikes.
Que89YJ is offline
post #9 of 14 Old 02-28-2013, 11:23 AM
TexasYJ
One trick I have used in the past is to take a 4' - 6' length of 1/4" tubing, insert one end in your ear and use the other end as an audible "sniffer" to test around the joints of the manifold. Once you find the spot, you will be able to hear the noise through the hose. Cheap and dirty stethoscope. Be wary of fans and belts when using this techniques, though.
TexasYJ is offline
post #10 of 14 Old 02-28-2013, 12:17 PM
Que89YJ
That is the pipe method. It works really well because you can block all the noise out except what you have at the end of the pipe.
Fault codes:
No Start:
Que89YJ is offline
post #11 of 14 Old 02-28-2013, 01:49 PM
TexasYJ
Sorry, Que I missed your post regarding that method....
TexasYJ is offline
post #12 of 14 Old 02-28-2013, 07:21 PM
Que89YJ
I didn't explain it at all you did. Thanks. Swipe on the cells helps but is a pita besides nice know we are thinking the same thing!
Fault codes:
No Start:
Que89YJ is offline
post #13 of 14 Old 03-04-2013, 01:52 PM
TexasYJ
Que, you an I generally tend to end up on the same page in most of our posts!
TexasYJ is offline
post #14 of 14 Old 03-04-2013, 02:49 PM
Que89YJ
Then I am in good company.
Fault codes:
No Start:
Que89YJ is offline
