Cracked engine block, need help with replacement. - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Cracked engine block, need help with replacement.
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge BushingsStainless Steel Door Hinge Pins
Unread 07-03-2008, 03:09 PM   #16
4.7stroker
true but you can still pull the plugs and peek under the valve cover.
Dwayne
4.7stroker is offline   Reply With Quote
