CPS removal - JeepForum.com
post #1 of 1 Old 03-01-2008, 05:04 PM Thread Starter
seattlejeepster
CPS removal
Does anyone know the trick to getting a CPS (crankshaft position sensor) off a '95 YJ 2.5L? I've removed the two nuts that hold it in place, but can't figure out how to remove it (the sensor doesn't seem to have enough give to pull it away from the bolts it's mounted on).
seattlejeepster is offline
A/C Removalů AR-Guy YJ Wrangler Technical Forum 11 11-03-2010 07:55 AM
Air Dam Removal liquidean JK Wrangler Technical Forum 8 09-11-2009 03:12 PM
Oil Pan Removal Help TjBryce TJ Wrangler Technical Forum 3 09-06-2009 04:21 PM
HT Removal Sidewalkman YJ Wrangler Technical Forum 4 07-12-2003 07:14 PM
hub nut removal black pete YJ Wrangler Technical Forum 5 07-10-2003 07:03 AM
